Scudo judder in reverse. Not engine mount. Any ideas??
robthewelder
I've noticed a lot of oil around back of engine recently. Occasionally the car had a slight rumble . I was suspecting work bearings ? Then the clutch judder began two weeks ago, I cannot reverse park because of this. I've changed master cylinder on clutch and fully bled the system. Still no good. Now getting vibrations through the van when i rev but smooth out with clutch depressed? Could this be something out of line? how difficult is it to split the gearbox and check the clutch and oil seal¿?? He'll needed urgently. Please.
Thankyou for input crazy.... Scudo 2.0jtd As it happens I kept limping it along as long as I could till it broke down entirely. Then I got it on the ramps to find that the idiots that changed the clutch had either not tightened the bolts or simply not put them in. Only held on by starter motor and one incorrect bolt. The thrust bearing was pushed through the fingers on pressure plate. I've now ordered a complete new clutch.
