hi,
if I read OBD using any universal software, it provides two values regarding EGR:
- Commanded EGR value (percentage 0-100)
- EGR ERROR (-100 to 100)
which is quite obvious what does they mean.
But when using MultiEcuScan it provides
- High pressure EGR valve opening %
- High pressure EGR actual position %
- High pressure EGR target position %
- Low pressure EGR valve opening %
- Low pressure EGR actual position mm
- Low pressure EGR target position mm
and couple more like control, learn etc.
My question is what is the difference between valve opening and actual position? As I assume "target" is what ECU wants it to be, "actual" is how really open it is, then what "valve opening" stands for?
Btw why Low values are in mm?
