FIAT Auto Specialist Team
Thread Tools
Old 14-05-2019   #1
USA
Intermittent Stalling while driving
I have a '71 Fiat 850 Sport Spider with a modified 903 cc motor (Bigger cam, 32/36 Weber carb, electronic ignition, electronic fuel pump, etc). I just brought the little guy out of a 5 year garage sleep to drive it this summer. I did the obligatory prep work including change the oil, oil filter (it is plumbed for a canister filter) antifreeze, check the carb jets for blockage, and spark plugs. The issue I am having is it will be running just fine and then stall out, sometimes after 5 blocks and sometimes after 5 miles. It stalls at 20 mph as well as 45 mph. It acts like the key was turned off. However, once at a stop i am able to pump the accelerator once and get it restarted.
So, I am looking for some direction on where to start. Or said another way, what is most likely to go bad sitting in an unheated garage in northern Minnesota for all of that time?
I could replace the electronic fuel pump? If that did not do the trick I could start with the coil?? The electronic ignition (Crane Fireball XR700)?? The ????
Any advice or tips would be appreciated.
Dave
850 Dave is offline Reply With Quote Quote
Old 15-05-2019   #2
USA
Thumbs up Re: Intermittent Stalling while driving
Yesterday I installed clear fuel line so I could see what was going on. I think that the heat in the engine compartment is boiling my fuel and otherwise creating a vapor lock. I am off to find out how to tap the Weber 32/34 DFT carb to install a return fuel line. I originally posted that the carb was a 32/36 but that was a typo,,,
Anyway, I will let you know how that goes.
Dave
Old 15-05-2019   #3
Quote Originally Posted by 850 Dave View Post
Dave
Have you drained the petrol and used fresh? 5 years in storage will not be good for the fuel, you might be surprised what fresh fuel does .....
Mad one is offline Reply With Quote Quote
Old 16-05-2019   #4
USA
When I parked the car I drained the gas tank and ran it out of fuel. So, it only has fresh non-oxygenated premium fuel running through it.
Likes Mad one liked this post
Thread Tools
(T) Punto intermittent stalling ? petel Punto (Mk1) 20 16-03-2011 11:58
(G) Intermittent bucking and stalling of sei Martine Cinquecento / Seicento 3 17-08-2007 17:53
(T) Cinq intermittent stalling problem Amsterdame Cinquecento / Seicento 4 29-05-2007 15:35
(G) Tipo 1.4ie intermittent stalling/jerking andy pocock Tipo (Classic) 6 12-03-2004 07:51
Fiat Bravo 1.8hlx Intermittent stalling Keith FIAT Boo Archives 2 19-11-2000 22:19
