Thanks Eklipze. I'm afraid a certain amount of havering comes free with me. But, if I do this, I'll try to control myself.
OK here we go. - As many will know a ready supply of compressed air when working on cars, bikes, machinery in general, is a very handy thing to have. Blowing the road grit out of spark plug recesses prior to removal, clearing carburetor jets, etc, etc. Early on I made do with a large old foot pump, a yard or so of flexible pipe and an old nozzle to give the jet. It worked quite well for the sort of thing described above as I could pump with my foot leaving one hand free to direct the jet and the other for manipulation. Then I got interested in spray painting. Can't do that without a compressor and I couldn't afford one.
Around that time, maybe 35 years ago, I was driving along, not far from home, passing the small body parts factor where I bought Panels/paint etc. Sitting on the pavement outside his shop was a rather unusual compressor. Knowing the staff quite well I popped my head round the door and asked what it was doing out there. "It's broke pal. - It's going to the scrapie as soon as the van gets back from deliveries". Could I have it? OK it'll save us a trip, but it's very old and doesn't pump. It took two of us to lift it into the back of my DAF 33 van and took the suspension down onto the bump stops, but I got it home without incident. It's biggest problem was that one of the "poppet" valve return springs was broken so it couldn't pump and it needed a new ball race on the pulley end of the electric motor. My local engineering supplies people, Forth Engineering, came up trumps on both items and, with a fresh sump of compressor oil, it ran whenever I needed it for roughly the next 25/30 years.
Here's a picture of my old "friend" just before I sold him.
I bought an SIP spray gun and resprayed the DAF! nearly asphyxiating myself with the fumes (cellulose in those days). The big drawback, which, in my ignorance I knew nothing about, is that you need lots of air to spray paint and my "pal" was a low capacity single cylinder device. It took around 15 to 20 minutes to bring that air receiver up to 100psi, so I could get only a few minutes spraying and then wait for 5 minutes or so till the pressure built up again. Around that time I bought my Clarke "windy" gun but hardly used it as it would only give one good burst before expiring asthmatically! The one thing I really liked about it was that it sounded like the single cylinder Field Marshal tractor I sometimes drove on the farm next door when I lived at home - Pock, Pock, Pock, Pock!
About 4 years ago I decided to treat myself to a compressor that could properly power the various air tools I'd accumulated over the years I'd thought a £300 budget would cover it and had "negotiated" this with Mrs Jock. I wanted a 50 litre or bigger receiver and I found that I could buy a direct coupled (motor and compressor in one unit) for that but when I found out how noisy and high revving they are I didn't feel I could subject my neighbours to it especially after my old quiet running machine. Then, quite by chance, I came across the Wolf Dakota being sold by UKHS. Direct drive, slow running, 3HP, 14CFU (is that free air though? the windy gun needs about 9) 90 litre receiver and MUCH less money than Clarke or similar. Spent about a week looking into it and found out that most of these small units are made in china. In fact when you start looking closely at them they are all pretty similar (bet a lot of them are made by the same people?). Ah well, you can't afford anything "better" Jock so it's either this or nowt! So, feeling very nervous that I might be making a big (expensive) mistake, I ordered it. Here it is being unbox
It's mounted on wheels so is very easy to move. Surprisingly it doesn't move around when running and it fits beautifully into the space where the old machine used to live.
It's advertised as suitable to run on a 13amp supply. Well yes it does BUT, only if it's a fused supply. My garage is on an RCD, the house is fused, it trips the RCD every time but runs happily for hours on the socket in the utility room. My friend's son (electrician) has explained it's all to do with the Capacitive starter. He also says it probably just about blows the fuse each time it starts but will only pull about half that when running. He's going to wire in a "proper" supply for me when he's not busy but it's been running like this, on an occasional use basis for a couple of years now. Also worth mentioning that, although not silent by any stretch of the imagination it is as quiet running as the old machine and MUCH MUCH quieter than a direct coupled machine. I notice SGS seem to be selling the same machine until recently at twice the price but now, on an offer, very slightly cheaper than UKHS.
Now to what might interest you Eclipze. What to do about plumbing? My first thought was to go for hard lines fixed to the wall ('cos that's the way I've always seen it done.) It was at this time I bought the CP 7748 and I got very interested in maximising air supply. Until then my couplings were all the old PCL type with 1/4" bore rubber hosing but the wolf came with the new metric type and I immediately noticed they have a considerably bigger bore. OOOH, more air! - PCL on the left metric on right.
The metric fittings were not so easy to source then so I popped round to Pirtek to have a chat. "The man" went away into his store to get what I wanted leaving me to wander round the small showroom. In the corner behind the door was a large coil of 1/2" bore rubber air hose. Hmm. If I use that it will give me much more flexibility than having it hard plumbed to the wall? (What with the compressor being wheel mounted and all). "What's with the hose behind the door then?" I asked him on his return. It's scrap, was run over by a forklift so can't be certified. I had a good look at it and could see the wheel marks in one small length only. Can I have it? "No, but I'll take silly money for it" I snapped it up and got about 40 feet of usable hose. It's plumbed directly into the end of the receiver via an isolating tap as you can see in the third image above. This leaves the built in regulated supply for connecting my air pistol.
This hose is long enough to let me reach not only anywhere in the garage but also to anywhere on the car when parked on the hard standing outside the garage door. Two drawbacks though. Being a large diameter it's not as flexible as a smaller hose and it has no pressure regulation - doesn't half make the Windy gun go though! Normally I have the compressor at the back of the workshop with the hose along the wall held in place by canvas slings. The last 20 foot is coiled just inside the garage door. When the pressure needs to be controlled I have a pressure regulator/moisture separator which the hose plugs into and a 3/8" bore hose (for better flexibility) leading off to the device (spray/underseal/cavity injection gun etc). I have this mounted on a separate "caddy" which also has storage space for appliances.
You can see the larger hose going in on the left and the smaller coming out on the right.
The old 1/4" bore hose now sees duty on my tyre inflator.
So you'd think I'd be happy now with my lovely compressor, powerful new air gun and other devices all working well. But it suddenly occurred to me that I've got some pretty long runs of hose going on here and long hoses equal pressure drop, don't they? So I decided to see if I could find a way of checking the actual pressure acting on the gun at the end of the hose. I took a selection of coupling pieces, buffed the rubber off the outside of a tyre valve and J B welded it to a hole I drilled in the side and ended up with this
Attaching my tyre inflator gauge to it let me monitor what was actually arriving at the gun inlet (Manufacturer recommended maximum of 90 psi)
Experimenting with this was very interesting and revealing. The compressor came with it's regulator set at 100 psi but the manual states it can cope with up to 150 psi (albeit, I suspect, with reduced life) I decided to increase it to 125 psi as I won't be putting the hours on it. With the CP connected to the 1/2" hose - so no regulator in circuit - it's an absolute hooligan! I can hardly think of anything on a car it wouldn't remove! Checking the pressure reveals barely a 5 psi drop at the gun when on full throttle! Now plug the 3/8" hose into the end of the !/2" and there is around 10 to 12 psi lost. Take off the 3/8 and plug in the 1/4" and right away the gun turns into a whimp. Pressure lost? not far off 30 psi at the gun. So by running, via the 1/2" hose to the caddy through the regulator/water trap and to the gun on the 3/8" (which gives me the flexibility of the smaller hose) I need to set the regulator to 105 psi approx to end up with the manufacturer recommend 90 psi at the gun. On the very infrequent occasion when i might run into something "supertight" I can just plug straight into the 12" hose and let "The Hooligan" loose.
