Thread Tools
Old 09-10-2018   #1
Key fob won't start engine
Hi
I'm on my second Panda, 11 years old now, and I bought a 2006 Panda for a friends daughter some years ago. This has now developed a fault in that the remote fob won't start the car. It still locks and unlocks the car. Most of the comments on the forum seem to relate to central locking with the fob, so I'm wondering if the fob can be reprogrammed or repaired in some way.
I also have a Mercedes SLK and when the fob stopped starting the car Mercedes wanted a gazillion quid to repair but a clever man repaired it somehow for modest quids and it's worked perfectly ever since, so it occurred to me there might be a similar service somewhere.
Panda2007 is offline Reply With Quote Quote
Old 09-10-2018   #2
s130 has donated!
Re: Key fob won't start engine
The key fob has two functions: opening/closing doors AND engine immobiliser deactivation.
Do you have a second key fob to try? If that fails to start the car then the fault is most probably with either the ignition key aerial around the ignition key barrel or the key control unit, or possibly the engine ECU.
Decent diagnostic kit like MultiECUScan is able to look at some ECU and Body Computer parameters that can help with diagnosis of key / immobiliser / etc issues.
s130 is offline Reply With Quote Quote
Old 09-10-2018   #3
varesecrazy has donated!
Quote Originally Posted by Panda2007 View Post
Hi
Do you have the key code? 4 digits.
Will be required if reprogramming a key into cars system.
Where are you based?
Charlie
Old 09-10-2018   #4
HI Guys and Thanks
There's no 4 number code on a neat plastic card in the wallet as one might expect, I will have a look in the car. Plus I've a bundle of old papers, it might be written there.
Regarding the keys, the second key starts the car no problem which suggests the issue is in the fob not in the car. Might the code be read off the second key?
Old 09-10-2018   #5
s130 has donated!
HI Guys and Thanks
This is good news.
To program a new key then your security pin code would be required.
Your remaining working key/chip could be cloned which is possibly the cheaper option. Cloning of keys is not normally recommend as the whole process of programming a new key requires all keys to be present so the missing / lost / stolen key can be deleted from the cars systems.
However in your case you have both keys so a cloning is a perfectly valid option. With luck it will just be the little RFID chip in the key fob that requires cloning and replacing thus avoiding the need to purchase a new key fob as well.
Old 10-10-2018   #6
minirib has donated!
Santas Factory Champion
Hi
The coil in the remote that is used to communicate with the immobiliser is likely broken or needs resoldering. Itís a very common problem on these remotes. It can generally be fixed very easily.
Do not try and reprogram the keys whilst ones not working or it will be deleted permanently and you wonít get it working again even if it is fixed later.
Likes s130, varesecrazy liked this post
minirib is offline Reply With Quote Quote
Old 11-10-2018   #7
s130 has donated!
Quote Originally Posted by minirib View Post
I was not aware of remote key fox coil issues so thanks, we live and learn.
As a slight side track point on modern vehicle security systems they are there actually to reduce insurance claim losses with insurance companies, saving them millions. So on that basis why do we have to pay additional money when the security system fails?
Thread Tools
(T) Fob not starting engine - spare key does bennyinkwell Panda 11 30-06-2018 17:06
(T) Engine won't start. Will the engine start with the MAP sensor wires unplugged? Ian S Cinquecento / Seicento 4 28-10-2016 21:49
(T) Engine won't start after turning key in ignition. 1MH1M4N Grande Punto 5 07-03-2016 19:05
(T) engine won't start won't bump start engine seized ? seanhyde Cinquecento / Seicento 43 23-01-2012 15:33
(T) MK2 2000 Engine change, key code light on. Won't start. johnhara1 Punto (Mk2/2b) 10 28-04-2011 23:59
