In another thread https://www.fiatforum.com/500/460683-my-2016-500c-write-off.html jrkitching noted that it was against a Code Of Practice (COP) to sell used airbags or other SRS components. This is off topic so here's a new thread.
@typecast boy said it is not economic to repair many cars without used SRS components. While I don't think it is good idea I posted a link to a pro sell used components report
http://www.bvsf.org.uk/cms/images/PDFs/MVDA-BVSF airbag report 16 03 2016.pdf
Having read this a bit more I disagree with some of their assertions.
1/ That an electrical continuity check gives confidence a device will work, it won't e.g. if seas have failed and moisture entered or gas escaped from a hybrid device.
2/ That devices don't degrade with time, they do. apart from chemical degradation, physical changes in the propellant can have big changes in performance. e.g. if a tablet type propellant starts to break up due to vibration etc. it has a larger surface area and can burn faster creating higher peak pressures or even detonation.
3/ that airbags are no-longer classed as dangerous good after they are fitted to the car and removed. This is just plain wrong, if you ship a whole car the airbags are considered dangerous goods. As an example an aircraft passenger lifejacket is considered dangerous goods due to the CO2 cylinder. You can't ship even one on a passenger aircraft as cargo even though there is one under every seat. There are good reasons for this.
Overall I think the paper is very biased.
Robert G8RPI
Robert G8RPI
