Jimmybill73
- Apr 24, 2018
- 3
- 1
I started up my 500 a week ago, and everything worked fine, but AI got a warning light and the Stop/Start deactivated.
I turned off the engine, and back on again, but the instrument cluster panel (fuel, revs, speedo, temperature etc.) was completely black - no LEDs at all. Even the indicator 'ticking' sounds can't be heard (although hazard lights do make the sounds).
Fuse-wise, I have changed all fuses, disconnected the battery, and even tried a different battery (also Fiat 500), and pleasingly, this worked - until I was about a mile into a journey and the warning lights came back on again - then, upon starting the engine, black background again.
I've been reading as much as I can about this, and I am reluctant to spend £££'s if it is a case of checking wiring/connections or something simple - essentially something I could do myself.
Could anyone be a star and let me know the things they think/know this could be, and how I would go about checking the wiring, connections etc.?
Thanks so much!
J
Thanks so much!
J
