Question to all JTD 1.9 8V (Multijet with EDC16) drivers and mechanics: What exactly is the most common cause of error code P0503? I take that it is not the tach generator as per the generic OBD list, as everything related to it is working fine (speedo, esp, anti-lock, 4wd).
Some other list on the net indicates that FIAT repurposed that code as an early warning for HP fuel system problems ("OBD/2 P0503 error code:
Fuel Rail Pressure Sensor in Range But Low")
Indeed I get the impression that the engine can be reluctant to start, especially after it has been sitting for a few days in the cold. So where would you start looking? Leak back test on injectors shows no irregularities, neither do the correction factors. No easily visible fuel leaks either...
