I started this thread because of a discussion here:
https://www.fiatforum.com/500/455287-battery-specs-3.html
It started with a "supercapacitor" comment.
My opinion is that LiFePO4 is not a viable "drop-in" replacement for lead acid in a modern car. Super capacitors on their own are a complete non starter. The only advantages of LiFePO4 are lighter weight, higher discharge currents and possible longer life. Proponents say you can use a battery of 1/4 to 1/10 the AH rating of the lead acid. I disagree mainly because they will not support the modern electrical systems when the engine is not running. Threr are several disadvantages, can't chrge below 0 Deg C, may need special chargers / battery management, can de distryed by discharging below ~8V.
Some links from both sides:
http://www.lithiummoto.com/faq.html
https://electronics.stackexchange.com/questions/137249/using-lifepo4-battery-as-car-battery
ttps://www.physicsforums.com/threads/replacing-a-lead-acid-12-volt-battery-with-a-lithium-ion-polymer-battery.294828/
http://www.diyelectriccar.com/forum...tions/221531/supercapacitors-as-car-batteries
Robert G8RPI
Robert G8RPI
