FIAT Auto Specialist Team
Thread Tools
Old 29-09-2017   #1
Clutch Slave cylinder connection - Fiat Ducato
A simple question for those in the know . . .
Iím intending to replace the clutch slave cylinder on my 2003 Ducato 2.8 JTD . On previous vehicles Iíve had, the hydraulic pipe has screwed into the slave cylinder. On the fiat though it looks as though the hydraulic pipe just pushes in and is kept in place with a retaining wire. Is this the case and/or is a specialist tool required to remove/refit the pipe? There's a picture in the gallery however I can't post it as I've insufficient postings to include a link.
Many thanks
Dethleffs is offline Reply With Quote Quote
Old 29-09-2017   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: Clutch Slave cylinder connection - Fiat Ducato
I'm not familiar with the Ducato, but the normal method with circlip retained clutch cylinder hoses is to remove the circlip completely to allow the hose to be withdrawn.
When fitting the new cylinder, push the hose in and refit the circlip, then pull the circlip out to it's first notch. This should allow the hose to be withdrawn just enough to bleed the cylinder via the nipple that's moulded as part of the cylinder. The nipple has a hexagon moulded onto it, but don't try turning it, or it will break off of the plastic cylinder.
In future, you're likely to get a better response to Ducato technical issues if you post in Ducato section of the forum here: https://www.fiatforum.com/ducato/
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 01-10-2017   #3
varesecrazy has donated!
Quote Originally Posted by Dethleffs View Post
Many thanks
I've not change one of the modern type either
there was a fair discussion in the 500 section about this,
one of the threads;
https://www.fiatforum.com/500/450372...nder-pipe.html
Charlie
Old 19-10-2017   #4
Thanks all, the clutch slave cylinder replacement went well. Darvenís description of the procedure is spot on. Once Iís got over the fact that it was just a push fit with a circlip for retention the process of connecting and bleeding the hose was remarkably quick. I canít imagine how it retains an hydraulic seal but it does!
By way of background, I replaced the slave cylinder because the clutch pedal was not always springing back to its initial position and if left would become progressively lower with use until it was pulled back up with the foot. It now performs as it should.
Likes Mad one, varesecrazy liked this post
Old 26-10-2017   #5
Thread Tools
(T) Clutch slave cylinder New schues Stilo 2 01-02-2017 10:13
(G) Clutch Slave cylinder thuraja Panda 7 16-08-2015 18:31
(T) 1.4 Tjet Clutch with Slave Cylinder or Concentric Slave Cylinder? Eridanny Bravo 9 22-12-2013 23:25
(T) Grande punto master clutch cylinder/slave cylinder Ramrodd Grande Punto 0 31-07-2013 18:43
(T) clutch slave cylinder -where is it davidthelodge Stilo 17 24-06-2010 23:13
