Cabin blower fan not working
Hello all!
After almost 2 weeks of search, I came to the worst conclusion: change the blower :cry:
My cabin fan stopped working out of nowhere, at any speed (1 to 4). I have checked all the fuses (in the cabin and those in the engine bay), I have checked the connection and the resistor and all is looking good (the resistor looks just a bit rusty, but nothing to interfere with the connectivity). :cry:
The only thing I could't check was the relay, as I don't know witch one is on the engine fuse box (I've read that it is red, but I have 3 and I can't find any diagram for bravo 2007 1.9 diesel).
The long thing short, I would appreciate any help on finding the relay and how to check it.
Hello all!
hi,:)
have you removed the fan, check it spins freely.. and doesn't smell burnt ?,
then give it 12 volts and check it spins;)
Charlie
Hi there. It is too much work to do removing the fan, even accessing it (by the layout I've seen, I have to dismantle the dashboard to access it). And I need the car daily for work, so no time for that. BUT i have found a burnt relay, the T08 in the engine compartment. So I'm gonna buy one and change that and see if it will work. _20170730_194526.JPG
Whit this occasion I've found out that on the back of the fuse box lid you find what every fuse and relay is for. :-D
Looks like you have found the problem. The full electronic workshop manual "eLearn" is in the Forum download section. https://www.fiatforum.com/downloads.php?do=download&downloadid=373
thanks to @Davren. It tkes a bit of effort to decompress and make a CDROM but its worth it. The system take a bit of getting used to but it's all there.
Do you have Climate control (digital temperture selection) or just basic aircon (hot-cold knob)? The Aircon uses simple resistors to control the speed, CC has an electronic speed control.
Robert G8RPI.
Sorry I was thinking of Croma's not Bravo
Robert.
Thanks for the link. I hope I will make some time to start reading manuals in the near future :)
It is the simpler version, with the hot-cold knob. I have a thought to change the panel to Climate Control, but not yet. No time or money for that.
