Hello.
I have a punto evo 2010. 1.3 turbo diesel 75hp. This is the 199b engine.
Big end noise on start up and light knock for first mile or two then clears and sounds fine. It also smokes but not all the time, can go for a week without smoking then one day it smokes for a few miles whether hot or cold. Thinking about taking sump off and checking end bearings for wear as needs sump anyway. As for smoking could it be injector fault as its intermittent.
If engine needs replacing what differences are there between 199a and 199b, and will the 90hp engine fit.
Also what other models would fit straight in.
Thank you in anticipation for any help.
