Thread Tools
Old 06-12-2016   #1
fuel light flashing
fuel light flashing punto 2000
I have read a few posts about the fuel light flashing and saying zero.
most of these posts say there car didn't start, this isn't the case for me,
I have had a fuel pump problem, the car was juddering and stalling and not getting much power, the pump was also whining loudly. so I go another fuel pump, fitted the pump and the car started but the fuel light started to flash and the gauge went to empty. (which means there is a fault in the system)
I put the old pump back in to check the car since last I started it and there was no flashing fuel light with the old pump.
I do have fuel in the car for those about to say that! probably half a tank.
so all the wires, injectors and fuel lines work with the old pump, so they aren't the problem either. the problem I guess, with the old pump was the filter was most likely clogged, hence the lack of fuel and stalling/juddering.
so the new pump works and starts the car, what could the problem be?
anyone with knowledge or similar problem happen?
thanks
chrizzz is offline Reply With Quote Quote
Thread Tools
(T) fuel light flashing chrizzz Punto (Mk2/2b) 5 07-12-2016 10:56
(T) Fuel light flashing but won't start (No spark) Radders567 Punto (Mk2/2b) 90 19-01-2016 11:55
(T) Punto 1.2 8v Active - Airbag Light/Flashing Oddometer/Fuel Filling Issue MaxTheLad Punto (Mk2/2b) 13 01-05-2015 15:44
(T) Dreaded flashing fuel light & non starter. pycoed Punto (Mk2/2b) 4 21-03-2014 23:17
(T) Fuel Light Flashing Crabthief Punto Evo 2 30-11-2012 11:46
