- May 26, 2011
- 232
- 161
I've a problem with my 2006 Doblo MJet 1.9 Diesel (https://www.fiatforum.com/doblo/443017-finally-happened-error-code-p1206.html), I've read up a bit on what might be causing the P1206 error code and I think the first things I should have a look at is the condition of the pipes around the wastegate valve and cleaning the EGR valve (Possibly sticking).
The readings for the EGR, which I get from Multiecuscan, show that when the ignition is on the EGR Control is OFF and the Valve opening is 4%. When the engine is running (tick-over to about 3000 rpm) the EGR Control fluctuates OFF/ON and the Valve opening fluctuates between the 4% and about 50%.
Does all that sound as if the EGR is working OK?
One imagines that the valve should open to 100%, or is it a quirk in the system where its maximum opening is just 50%?
Any advice much appreciated.
Ron
Ron
