Thread Tools
Old 05-04-2016   #1
Estonia
Fiat Albea not start
Hello, i need help to find a problem my 2008 Fiat Albea 1.4 57kw.
In the cold mornings car start and shut down. I tried many times but not starting.
Okey, i call a friend who come with diagnostic equipment and find that intake air temp is 70C, but outside temp is 5C.
When i unplug the intake map sensor the car start and i can drive but its not correct to drive when the plug is not connected.
I ordered a new Intake MAP sensor (0 261 230 030).
Yesterday my friend came and put it in the place, all faults deleted and trying to start, but same result, start and shut down..
New sensor shows correct outside temp and when i unplug the new sensor and start the car and put the plug back the car stops when plug connected.
Car coolant temp sensor working, maybe someone can help me
Thanks.
I put some pictures.
ID:	166453   Click image for larger version
kartul678 is offline Reply With Quote Quote
Old 05-04-2016   #2
varesecrazy has donated!
Quote Originally Posted by kartul678 View Post
Thanks.
Is this the 8 valve engine. As found in the grande punto..
Answer may be found there.
Old 05-04-2016   #3
Estonia
Re: Fiat Albea not start
Quote Originally Posted by varesecrazy View Post
Yes, 1.4 57kw 8V
Old 05-04-2016   #4
Estonia
Someone know whats the problem?
Old 05-04-2016   #5
the pics seem to take an age to open..,
I've given up..!!
https://www.fiatforum.com/grande-pun...tting-out.html
https://www.fiatforum.com/grande-pun...d-starter.html
GUIDE =https://www.fiatforum.com/grande-punto-guides/227405-1-2-1-4-map-sensor-replacement.html
let us know what you find.
did you get an error code with YOUR MAP sensor unplugged..??
Old 05-04-2016   #6
Estonia
I've given up..!!
Yes, when MAP is unplugged i have 2 fault.
Manifold absolute pressure and intake air temperature.
Starter works fine, engine temp is 90C and i plug the old sensor and intake air temp is 70C, engine not shut down but idle fluctuated, and one fault code is active: Mass or Volume air flow.
Maybe the new sensor is faulty?
Old 05-04-2016   #7
Estonia
Where i can find MAP sensor wiring scheme?
1-2-3-4 pin?
What is what?
I try new sensor temp sensor and old sensor absolute pressure to find out is the new sensor is faulty or not.
Old 11-04-2016   #8
Estonia
1-2-3-4 pin?
What is what?
Someone?
Thread Tools
(T) Fiat Albea not start kartul678 Palio 7 06-04-2016 10:36
(G) Fiat Albea Jalope Other Fiats 1 08-03-2016 10:00
(T) Fiat Albea Jalope Other Fiats 0 07-02-2016 11:22
(T) Fiat Albea and no sound immortals Other Fiats 0 05-06-2010 11:10
(G) FIAT Albea / Siena punto_2002 Other Fiats 23 05-06-2009 09:25
