Thread Tools
Old 20-12-2015   #1
Citroen nemo oil pressure switch
Hi all. I'm new to the forum. I have a 2011 Citroen nemo van 1248cc engine and I was wondering if anyone could tell me where the oil pressure switch is. It has gone into limp mode and the oil light is flashing and it's giving a oil sensors fault code. Thanks. Alan
Crombie is offline Reply With Quote Quote
Old 20-12-2015   #2
varesecrazy has donated!
Re: Citroen nemo oil pressure switch
Quote Originally Posted by Crombie View Post
Hi, and welcome,
is that a FIAT engine..?? I don't recognise the capacity,
maybe look at the bottom of FF homepage,
for the similar bodied FIAT van /combi,
somebody with another PSA vehicle posted this week looking for info,
Charlie
Old 20-12-2015   #3
Hi. It's a fiat f13dte5 engine. I think it's classed as a 1300
Old 20-12-2015   #4
if it's what's normally referred to as the Multijet,
then the Panda section will have plenty of info,
use this to navigate the parts..
http://eper.fiatforum.com/eper/navi?...=3&WINDOW_ID=1
Old 20-12-2015   #5
I have had a search but could not find any info
Old 20-12-2015   #6
https://www.fiatforum.com/fiorino-ii...ml#post4127969
Old 20-12-2015   #7
I found that. That's about turning the lights out. I am wondering where the oil pressure switch is located on the engine
Old 20-12-2015   #8
Hi again Alan,
you're probably better posting a specific oil sensor question in the relevant VAN section,
most little fiats have the sensor on the FRONT of the engine - near the filter
( + cooler lines if fitted)
I'm still not 100% yours it a FIAT though ,
the quoted post seems to suggest it might not be..,
but posting in the Fiorino , or similar section may be of more help,
good luck,
Charlie
Old 20-12-2015   #9
Trader Rating: 1
portland_bill has donated!
This is a Qubo or Fiorino as a Fiat.
Uses the Fiat 1.3 diesel engine.
The oil pressure switch is on the back of the head, I think, but this query is not an oil pressure issue, but an oil quality issue. It has calculated or detected poor oil quality, and is demanding an oil change and reset. There will be instructions in the handbook, but to haev gone limp suggests the warnings have been ignored and may need dealer intervention.
As suggested, post in Qubo or Fiorino forum for specific advice.
13 years motor trade, 16 years motor industry. 13 years Driving Instructor & 6 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 20-12-2015   #10
Yes this is rite. The oil was changed but the light was never reset so I assume I thinks it's still not been changed. Now when plugged in I get a error code saying fault code. P0521 Engine oil pressure sensor/ switch circuit range/ performance So that's why I think the sensor is faulty
Old 21-12-2015   #11
Trader Rating: 1
Engine fault codes have to conform to a standard. Manufacturers are allowed to create their own codes for some things, such as specific body functions, but there are a lot of common faults that must conform. The codes were created probably before oil condition became an issue, but any warning must be a universal code. It appears that this one has been used.
It is important with any code to not just rush to the first thought, but to use it as a pointer for proper diagnosis. If oil pressure was an issue, it would put a light on, as the switch is just that, on, or off.
If the computer has not been told about the oil change, it is still counting from the previous change, and has decided that it now will be ineffective as a lubricant. To protect the engine, it is now preventing any real performance, so needs the service/oil quality indicator resetting. However, depending how long it has been in this condition, a simple reset may not be enough. You will almost certainly need a trip to the dealer.
Panda Alessi
Thread Tools
(G) Peugeot Bipper, Citroen Nemo, Fiat Fiorino JimbbobW1977 Grande Punto 31 10-08-2015 00:55
My Citroen Nemo Anto78 Members Motors (Non-FIAT) 0 05-09-2013 21:33
(T) oil pressure switch andy3030 Cinquecento / Seicento 10 01-08-2011 19:18
(G) Citroen Nemo overturns in Which? Test Islander500 Qubo 41 27-09-2010 21:31
