hi all i have a 1.2 8v punto on an x/2000 plate and it has the strangest problem
it idles perfectly the moment you try and give it some throttle it pops and bangs then clears itself once over 2000 rpm between idle and this rev range its horrendous
car is a genuine 57k car
its had
new coil packs
leads
plugs
throttle body
lambda sensor
crankshaft sensor
fuel pump removed and cleaned
timinf has all been checked and spot on
compression tested and is between 175/200 psi across all 4
im slowly losing the will to live with it as no one seems to know whats wrong
any help pointers would be hugely appreciated thanks steve
its had
new coil packs
leads
plugs
throttle body
lambda sensor
crankshaft sensor
