Ok
I know these are loved/hated gearboxes but when working they are great......... IMHO
I have one with low pressure fault P1773
So I changed the accumulator and after some re-calibrating all worked ok
for a while after clearing fault codes for low pressure and pressure switch low input fault code, I thought it was just air needing bleeding.
Then I noticed fluid coming out of the pressure switch on the front of the valve body it has a three wire plug.
The car was driving ok didn't seem to leak when moving only when stopped with the engine off.
Now its back to the fault before and I cant move it it wont select any gears.
Any helpful advice would be appreciated.
