Old 29-12-2013   #1
Punto 1.2 2003 power steering problem
Hi, All.
New in here, having a problem with the power steering, it stopped working so I checked the fuses they were both OK I also tapped the relays and it worked for a short while.
It would seem that I have a faulty relay (please god) problem is I gave all the relays a knock and I do not know which is the one(s) control the steering.
Can somebody point out which one(s) I need to look at?
Thanks, Barry.
trebby91 is offline Reply With Quote Quote
Old 30-12-2013   #2
Brain stopped play
homeward's Avatar
Trader Rating: 1
homeward is part of the official FF Events Team :)
homeward has donated!
Re: Punto 1.2 2003 power steering problem
Welcome...!
It's more likely to be a dying battery -- especially at this time of year -- that causes the PAS to go on a Mk2 Punto; and it's a fairly common problem.
Have you got the red PAS light staying on, on the dashboard; and have you tested the battery output (i.e. voltage across the battery terminals: when stopped; then engine running; then lights and heater fan on...); or had it properly drop tested at your nearest motor factors...?
Sometimes it is the PAS motor that needs replacing; but report back, and someone who's had some sleep will be able to help. Good luck!
1990 Panda 750L Formula '90: Pippin (26,131 miles; 47.18 mpg)
2009 Panda 1.2 Eleganza Dualogic: Pandora (55,670 miles; 47.87 mpg)
2002 Punto 1.2 16v ELX Speedgear: Priscilla (100,465 miles; 41.30 mpg)
homeward is offline Reply With Quote Quote
(T) power steering problem on 06 Punto Yvonne147 Grande Punto 16 10-08-2013 12:35
(T) Punto Mk 2 power steering problem ste76 Punto (Mk2/2b) 1 04-06-2010 09:12
(G) Punto Power Steering Problem zadie Punto (Mk2/2b) 6 21-12-2007 12:19
(T) 2003 Mk2 Power Steering and City button CrArC Punto (Mk2/2b) 2 23-09-2006 17:06
