Fiat Palio Weekend 1,6-16V= OBD2?
Hi Peter,
Found this old thread. Did you find anything out? I think we have the same model.
I'm probably getting Multiecuscan for my Ducato and hoped it would address my Palio as well.
Cheers,
David
I don't have a full list, but this is part of the session:-
READING PARAMETERS:
Engine speed: 1050 rpm
Engine temperature: 53 °C
Spark advance: 0.5 deg.
Injection time: 4.5792 ms
Knock sensor signal: 0.0000 V
Engine load: 123.76 mg/i
Intake pressure: 386 mBar
Lambda sensor signal: 0.8673 V
Engine start permission: Allowed
And:
READING PARAMETERS:
Engine start permission: Not Allowed
EXECUTING ACTUATOR...
Failure indicator light
COMPLETED
RPM Counter
COMPLETED
Fuel pump relay
COMPLETED
Evaporation control valve
COMPLETED
Interesting that my key code indicator has been overridden somehow by the dealer (intermittent problem), but the ECU is aware of the true status.
If I have time tomorrow I'll run a full session. She's up on blocks at the moment following brake and transmission boot change.
I did some screen caps of the interface.
Good afternoon,where is the diagnoctic input on my fiat Palio weekend 1.6 16v 2004 model
I had a 1999/2000 model (now sadly departed :( ).
It had a 3 pin plug/socket under the bonnet, I can't remember exactly where.
Do you have the 3-way adapter? I may have one still if you don't, but postage might be an issue.
