Creaking / Knocking noise when pulling off - 1.9Jtd
Elburg
I have had some problem the last couple of months with my 1.9 GP Sport.
The first problem was stuttering while cruising @ 1500rpm.
This was caused by a faulty EGr valve, this has been replaced but now two new problems occur:
First problem:
When pulling of I hear a creaking / knocking noise when I pull of.
I first thought it was the clutch but when I pull up just but letting go of the clutch there's no sound.
If I hit the gas after that I do hear the sound.
I can also hear it in other gears but not as clear as I'm driving faster.
Second problem:
When accelerating I can hear the turbo spinn.
Around 2000 / 2200 rpm it suddenly starts stuttering and I can hear the turbo flutter. Sounds like the throttle is closed suddenly.
I realy would lik to know the cause of the first problem as I cannot prevent it from happening.
Problem 1 is fixed.
It turned out to be bar underneath the car that was hitting the gearbox when pulling of.
The engine rol's back quite a bit when you hit the gas.
Problem 2 is also fixed but i don't know how.
It just stopped doing it.
