I started a thread about my Daughters punto that failed its MOT on Emissions around a week ago. The car was bought as a bodywork project and hasnt moved off the drive until its MOT. I thought it could be a fuelling problem but it smokes and ive never seen that on overfuelling. I have seen an engine burning oil and this looks like it could be doing just that. The engine has done 77k ive changed the plugs and the old ones were not fouled with oil. Ive also changed the air filter and was about to do the lambda sensor until I saw there are two sensors on the exhaust so I need to find out which I need to change or both.
So my symtoms are it ticks over fine and spits a little bit of soot and I mean tiny bits. Now if you keep reving it hard you get a blueish smoke and lots of it until you back off the throttle. If you let it tick over no smoke, for this reason I suspect worn valve stem oil seals and this would effect the emissions. If anyone agrees or has had the same problem please reply. I dont want to rip the head off and buy gaskets and seals for someone to say its a blocked breather lol.
