I'm assuming you are still referring to your car which has had the DPF removed, or are you looking to recover your original DPF.
Assuming no DPF, then a forced regen may initially clear the DPF readings but they will certainly return very quickly.
FiatECUScan (
http://fiatecuscan.net/) can do this. Basic software is free but you need to buy some hardware.
A KKL interface you can get for less than £20.
Not wanting to question you, but I'm not sure where you are going with this DPF thread.
If you have removed your DPF then you have only two options.
1) have the ECU reprogrammed
2) fool the ECU to thinking a DPF is still fitted.
On point 2) I and others have speculated ways to do this in this/other threads. However none of us have tried them because we don't need to YET.
Unless you make some serious steps in 1) or 2) then apart from huge ammounts of lost time then you seriously risk damaging you engine.
An ECU reprogram will cost £200 to £500. A new DPF £800 to £1500. It is IMHO getting to the point in time where you have to bite the bullet and choose a solution.
This is all new ground for many of us here. I'm well experienced, have software and hardware experience, am electronics/software engineer by training, with plenty of kit such as electonic vacuum/pressure guages, meters, scopes & signal generators etc. etc.
I don't have a DPF issue (yet) but have offered ideas / suggestions as have others and we are getting close to the point not being to help you any further. If I hit a DPF problem then I'll be fired up to investigate in greater detail but at the moment I/we have no need and YOU are nearer the "front" than we are.
