raw109
Does anybody know is there is an electric water pump available for this engine?
I can see where your coming from but the cooling system is for the engine only isn't it
So can't pump be on belt and stop and start when the engine does?
Porject sounds awsome though
I wish it was that simple. We are using the engine as a large heat-sink instead of using the heat exchangers when our temperature is a certain range. We are doing this so that we can preheat the engine block which will almost eliminate cold start emissions. Once the coolant temperature coming out of the block is too warm for the coolant temperature entering our batteries we will then have a diverter valve that will change the flow from going through the engine to the heat exchangers. I know it seems kind of crazy but we have the most innovative idea on component cooling for this competition. Worst case scenario I can machine a plate that will block off the hole for the water pump and place a pump just after thermostat on the back of the engine but an electric replacement pump would be a lot better.
yoiu ought to be carefull with changing the pump as when the engine is running it's original pump will have carefully worked out volume and flow rates dependant on the correct cooling for the engine you could cause hot spots in the engine
There is a team of 30 student engineers that have looked into all aspects of this cooling system so we are not worried at all. I would assume though that since no one has mentioned an electric replacement then one does not exist. That is not what I wanted :bang:. I will just use an inline pump. No worries.
I'm not sure there is any current road going car fitted with and electic water pump.
However electric water pumps to exist for other applications. If I were involved with this project I would be possibly looking for a variable spped pump that can be controlled to adjust water flow to provide optimum engine temperature when running and optimum cooling as required.
Such a pump should allow you to remove the thermostat. The thermostat is a flow restriction device thus requiring additional pump energy to keep water flow at any rate.
To avoid powerloss if you can't pulse width modulate the pump then you could use several smaller pumps in parallel and switch them on/off as required.
Possibly not suitable "Whale" do in-line pumps (1/2inch with various volume rates) for caravans etc.) These a 12V powerfull pumps but I'm not sure of their efficiency.
Anyway, enough ideas from me. Time for you student engineers to take over
