EOBD Error Code List
acefreecell
Ace new album 15/09/2009
Heage
Hear is the list of the Generic EOBD error codes:
EOBD Generic Fault codes beginning P00xx - Fuel and Air Metering
  • P0001 Fuel Volume Regulator Control Circuit/Open
  • P0002 Fuel Volume Regulator Control Circuit Range/Performance
  • P0003 Fuel Volume Regulator Control Circuit Low
  • P0004 Fuel Volume Regulator Control Circuit High
  • P0005 Fuel Shutoff Valve Control Circuit/Open
  • P0006 Fuel Shutoff Valve Control Circuit Low
  • P0007 Fuel Shutoff Valve Control Circuit High
  • P0008 Engine Position System Performance (Bank1)
  • P0009 Engine Position System Performance (Bank2)
  • P0010 A Camshaft Position Actuator Circuit (Bank1)
  • P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
  • P0012 A Camshaft Position - Timing Over-Retarded (Bank 1)
  • P0013 B Camshaft Position - Actuator Circuit (Bank1)
  • P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
  • P0015 B Camshaft Position - Timing Over-Retarded (Bank 1)
  • P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)
  • P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
  • P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
  • P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)
  • P0020 A Camshaft Position Actuator Circuit (Bank 2)
  • P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
  • P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
  • P0023 B Camshaft Position - Actuator Circuit (Bank 2)
  • P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
  • P0025 B Camshaft Position - Timing Over-Retarded (Bank 2)
  • P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
  • P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
  • P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
  • P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
  • P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
  • P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
  • P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
  • P0033 Turbo Charger Bypass Valve Control Circuit
  • P0034 Turbo Charger Bypass Valve Control Circuit Low
  • P0035 Turbo Charger Bypass Valve Control Circuit High
  • P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
  • P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
  • P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
  • P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
  • P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
  • P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
  • P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
  • P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
  • P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
  • P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
  • P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
  • P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
  • P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
  • P0049 Turbo/Super Charger Turbine Overspeed
  • P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
  • P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
  • P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
  • P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
  • P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
  • P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
  • P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
  • P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
  • P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
  • P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
  • P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
  • P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
  • P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
  • P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
  • P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
  • P0065 Air Assisted Injector Control Range/Performance
  • P0066 Air Assisted Injector Control Circuit or Circuit Low
  • P0067 Air Assisted Injector Control Circuit High
  • P0068 MAP/MAF Throttle Position Correlation
  • P0069 Manifold Absolute Pressure Barometric Pressure Correlation
  • P0070 Ambient Air Temperature Sensor Circuit
  • P0071 Ambient Air Temperature Sensor Range/Performance
  • P0072 Ambient Air Temperature Sensor Circuit Low
  • P0073 Ambient Air Temperature Sensor Circuit High
  • P0074 Ambient Air Temperature Sensor Circuit Intermittent
  • P0075 Intake Valve Control Solenoid Circuit (Bank 1)
  • P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
  • P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
  • P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
  • P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
  • P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
  • P0081 Intake Valve Control Solenoid Circuit (Bank 2)
  • P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
  • P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
  • P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
  • P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
  • P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
  • P0087 Fuel Rail/System Pressure - Too Low
  • P0088 Fuel Rail/System Pressure - Too High
  • P0089 Fuel Pressure Regulator 1 Performance
  • P0090 Fuel Pressure Regulator 1 Control Circuit
  • P0091 Fuel Pressure Regulator 1 Control Circuit Low
  • P0092 Fuel Pressure Regulator 1 Control Circuit High
  • P0093 Fuel System Leak Detected Large Leak
  • P0094 Fuel System Leak Detected Small Leak
  • P0095 Intake Air Temperature Sensor 2 Circuit
  • P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
  • P0097 Intake Air Temperature Sensor 2 Circuit Low
  • P0098 Intake Air Temperature Sensor 2 Circuit High
  • P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
EOBD Generic Fault codes beginning P01xx - Fuel and Air Metering
  • P0100 Mass or Volume Air flow Circuit Malfunction
  • P0101 Mass or Volume Air flow Circuit Range/Performance Problem
  • P0102 Mass or Volume Air Flow Circuit low Input
  • P0103 Mass or Volume Air flow Circuit High Input
  • P0104 Mass or Volume Air flow Circuit Intermittent
  • P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
  • P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
  • P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
  • P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
  • P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
  • P0110 Intake Air Temperature Circuit Malfunction
  • P0111 Intake Air Temperature Circuit Range/Performance Problem
  • P0112 Intake Air Temperature Circuit Low Input
  • P0113 Intake Air Temperature Circuit High Input
  • P0114 Intake Air Temperature Circuit Intermittent
  • P0115 Engine Coolant Temperature Circuit Malfunction
  • P0116 Engine Coolant Temperature Circuit Range/Performance Problem
  • P0117 Engine Coolant Temperature Circuit Low Input
  • P0118 Engine Coolant Temperature Circuit High Input
  • P0119 Engine Coolant Temperature Circuit Intermittent
  • P0120 Throttle Pedal Position Sensor/Switch A Circuit Malfunction
  • P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
  • P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
  • P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
  • P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
  • P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
  • P0126 Insufficient Coolant Temperature for Stable Operation
  • P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
  • P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
  • P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
  • P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
  • P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
  • P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
  • P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
  • P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
  • P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
  • P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
  • P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
  • P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
  • P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
  • P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
  • P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
  • P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
  • P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
  • P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
  • P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
  • P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
  • P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
  • P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
  • P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
  • P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
  • P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
  • P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
  • P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
  • P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
  • P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
  • P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
  • P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
  • P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
  • P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
  • P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
  • P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
  • P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
  • P0170 Fuel Trim Malfunction (Bank 1)
  • P0171 System Too Lean (Bank 1)
  • P0172 System Too Rich (Bank 1)
  • P0173 Fuel Trim Malfunction (Bank 2)
  • P0174 System Too Lean (Bank 2)
  • P0175 System Too Rich (Bank 2)
  • P0176 Fuel Composition Sensor Circuit Malfunction
  • P0177 Fuel Composition Sensor Circuit Range/Performance
  • P0178 Fuel Composition Sensor Circuit Low Input
  • P0179 Fuel Composition Sensor Circuit High Input
  • P0180 Fuel Temperature Sensor A Circuit Malfunction
  • P0181 Fuel Temperature Sensor A Circuit Performance
  • P0182 Fuel Temperature Sensor A Circuit low Input
  • P0183 Fuel Temperature Sensor A Circuit High Input
  • P0184 Fuel Temperature Sensor A Circuit Intermittent
  • P0185 Fuel Temperature Sensor B Circuit Malfunction
  • P0186 Fuel Temperature Sensor B Circuit Range/Performance
  • P0187 Fuel Temperature Sensor U Circuit Low Input
  • P0188 Fuel Temperature Sensor B Circuit High Input
  • P0189 Fuel Temperature Sensor B Circuit Intermittent
  • P0190 Fuel Rail Pressure Sensor Circuit Malfunction
  • P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
  • P0192 Fuel Rail Pressure Sensor Circuit Low Input
  • P0193 Fuel Rail Pressure Sensor Circuit High Input
  • P0194 Fuel Rail Pressure Sensor Circuit Intermittent
  • P0195 Engine Oil Temperature Sensor Malfunction
  • P0196 Engine Oil Temperature Sensor Range/Performance
  • P0197 Engine Oil Temperature Sensor Low
  • P0198 Engine Oil Temperature Sensor High
  • P0199 Engine Oil Temperature Sensor Intermittent / Erratic
EOBD Generic Fault codes beginning P02xx - Fuel and Air Metering
  • P0200 Injector Circuit Malfunction
  • P0201 Injector Circuit Malfunction - Cylinder 1
  • P0202 Injector Circuit Malfunction - Cylinder 2
  • P0203 Injector Circuit Malfunction - Cylinder 3
  • P0204 Injector Circuit Malfunction - Cylinder 4
  • P0205 Injector Circuit Malfunction - Cylinder 5
  • P0206 Injector Circuit Malfunction - Cylinder 6
  • P0207 Injector Circuit Malfunction - Cylinder 7
  • P0208 Injector Circuit Malfunction - Cylinder 8
  • P0209 Injector Circuit Malfunction - Cylinder 9
  • P0210 Injector Circuit Malfunction - Cylinder 10
  • P0211 Injector Circuit Malfunction - Cylinder 11
  • P0212 Injector Circuit Malfunction - Cylinder 12
  • P0213 Cold Start Injector 1 Malfunction
  • P0214 Cold Start Injector 2 Malfunction
  • P0215 Engine Shutoff Solenoid Malfunction
  • P0216 Injection Timing Control Circuit Malfunction
  • P0217 Engine Overtemp Condition
  • P0218 Transmission Over Temperature Condition
  • P0219 Engine Over Speed Condition
  • P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
  • P0221 Throttle/pedal Position Sensor/Switch B Circuit Range/Performance Problem
  • P0222 Throttle/pedal Position Sensor/Switch B Circuit Low Input
  • P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
  • P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
  • P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
  • P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
  • P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
  • P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
  • P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
  • P0230 Fuel Pump Primary Circuit Malfunction
  • P0231 Fuel Pump Secondary Circuit Low
  • P0232 Fuel Pump Secondary Circuit High
  • P0233 Fuel Pump Secondary Circuit Intermittent
  • P0234 Engine Overboost Condition
  • P0235 Turbocharger Boost Sensor A Circuit Malfunction
  • P0236 Turbocharger Boost Sensor A Circuit Range/Performance
  • P0237 Turbocharger Boost Sensor A Circuit Low
  • P0238 Turbocharger Boost Sensor A Circuit High
  • P0239 Turbocharger Boost Sensor B Circuit Malfunction
  • P0240 Turbocharger Boost Sensor B Circuit Range/Performance
  • P0241 Turbocharger Boost Sensor B Circuit Low
  • P0242 Turbocharger Boost Sensor B Circuit High
  • P0243 Turbocharger Wastegate Solenoid A Malfunction
  • P0244 Turbocharger Wastegate Solenoid A Range/Performance
  • P0245 Turbocharger Wastegate Solenoid A low
  • P0246 Turbocharger Wastegate Solenoid A High
  • P0247 Turbocharger Wastegate Solenoid B Malfunction
  • P0248 Turbocharger Wastegate Solenoid B Range/Performance
  • P0249 Turbocharger Wastegate Solenoid B Low
  • P0250 Turbocharger Wastegate Solenoid B High
  • P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
  • P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
  • P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
  • P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
  • P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
  • P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
  • P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
  • P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
  • P0259 Injection lump Fuel Metering Control "B" High (Cam/Rotor/Injector)
  • P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
  • P0261 Cylinder 1 Injector Circuit Low
  • P0262 Cylinder 1 Injector Circuit High
  • P0263 Cylinder 1 Contribution/Balance Fault
  • P0264 Cylinder 2 Injector Circuit Low
  • P0265 Cylinder 2 Injector Circuit High
  • P0266 Cylinder 2 Contribution/Balance Fault
  • P0267 Cylinder 3 Injector Circuit Low
  • P0268 Cylinder 3 Injector Circuit High
  • P0269 Cylinder 3 Contribution/Balance Fault
  • P0270 Cylinder 4 Injector Circuit Low
  • P0271 Cylinder 4 Injector Circuit High
  • P0272 Cylinder 4 Contribution/Balance Fault
  • P0273 Cylinder 5 Injector Circuit Low
  • P0274 Cylinder 5 Injector Circuit High
  • P0275 Cylinder 5 Contribution/Balance Fault
  • P0276 Cylinder 6 Injector Circuit Low
  • P0277 Cylinder 6 Injector Circuit High
  • P0278 Cylinder 6 Contribution/Balance Fault
  • P0279 Cylinder 7 Injector Circuit Low
  • P0280 Cylinder 7 Injector Circuit High
  • P0281 Cylinder 7 Contribution/Balance Fault
  • P0282 Cylinder 8 Injector Circuit Low
  • P0283 Cylinder 8 Injector Circuit High
  • P0284 Cylinder 8 Contribution/Balance Fault
  • P0285 Cylinder 9 Injector Circuit Low
  • P0286 Cylinder 9 Injector Circuit High
  • P0287 Cylinder 9 Contribution/Balance Fault
  • P0288 Cylinder 10 Injector Circuit Low
  • P0289 Cylinder 10 Injector Circuit High
  • P0290 Cylinder 10 Contribution/balance Fault
  • P0291 Cylinder 11 Injector Circuit Low
  • P0292 Cylinder 11 Injector Circuit High
  • P0293 Cylinder 11 Contribution/balance Fault
  • P0294 Cylinder 12 Injector Circuit Low
  • P0295 Cylinder 12 Injector Circuit High
  • P0296 Cylinder 12 Contribution/Balance Fault
EOBD Generic Fault Codes starting P03xx - Ignition System and Misfire Detection
  • P0300 Random/Multiple Cylinder Misfire Detected
  • P0301 Cylinder 1 Misfire Detected
  • P0302 Cylinder 2 Misfire Detected
  • P0303 Cylinder 3 Misfire Detected
  • P0304 Cylinder 4 Misfire Detected
  • P0305 Cylinder 5 Misfire Detected
  • P0306 Cylinder 6 Misfire Detected
  • P0307 Cylinder 7 Misfire Detected
  • P0308 Cylinder 8 Misfire Detected
  • P0309 Cylinder 9 Misfire Detected
  • P0310 Cylinder 10 Misfire Detected
  • P0311 Cylinder 11 Misfire Detected
  • P0312 Cylinder 12 Misfire Detected
  • P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
  • P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
  • P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
  • P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
  • P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
  • P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
  • P0327 Knock Sensor 1 Circuit low Input (Bank 1 or Single Sensor)
  • P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
  • P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
  • P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
  • P0331 Knock Sensor 2 Circuit Range/Performance (Bank )
  • P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
  • P0333 Knock Sensor 2 Circuit High Input (Bank 2)
  • P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
  • P0335 Crankshaft Position Sensor A Circuit Malfunction
  • P0336 Crankshaft Position Sensor A Circuit Range/Performance
  • P0337 Crankshaft Position Sensor A Circuit Low Input
  • P0338 Crankshaft Position Sensor A Circuit High Input
  • P0339 Crankshaft Position Sensor A Circuit Intermittent
  • P0340 Camshaft Position Sensor Circuit Malfunction
  • P0341 Camshaft Position Sensor Circuit Range/Performance
  • P0342 Camshaft Position Sensor Circuit Low Input
  • P0343 Camshaft Position Sensor Circuit High Input
  • P0344 Camshaft Position Sensor Circuit Intermittent
  • P0350 Ignition Coil Primary/Secondary Circuit Malfunction
  • P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
  • P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
  • P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
  • P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
  • P0355 Ignition Coil B Primary/Secondary Circuit Malfunction
  • P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
  • P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
  • P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
  • P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
  • P0360 Ignition Coil I Primary/Secondary Circuit Malfunction
  • P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
  • P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
  • P0370 Timing Reference High Resolution Signal A Malfunction
  • P0371 Timing Reference High Resolution Signal A Too Many Pulses
  • P0372 Timing Reference High Resolution Signal A Too Few Pulses
  • P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
  • P0374 Timing Reference High Resolution Signal A No Pulses
  • P0375 Timing Reference High Resolution Signal B Malfunction
  • P0376 Timing Reference High Resolution Signal B Too Many Pulses
  • P0377 Timing Reference High Resolution Signal B Too Few Pulses
  • P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
  • P0379 Timing Reference High Resolution Signal B No Pulses
  • P0380 Glow Plug/Heater Circuit "A" Malfunction
  • P0381 Glow Plug/Heater Indicator Circuit Malfunction
  • P0382 Glow Plug/Heater Circuit "B" Malfunction
  • P0385 Crankshaft Position Sensor B Circuit Malfunction
  • P0386 Crankshaft Position Sensor B Circuit Range/Performance
  • P0387 Crankshaft Position Sensor B Circuit Low Input
  • P0388 Crankshaft Position Sensor B Circuit High Input
  • P0389 Crankshaft Position Sensor B Circuit Intermittent
EOBD Generic fault Codes starting P04xx - Auxiliary Emission Controls. EGR, EVAP etc.
  • P0400 Exhaust Gas Recirculation Flow Malfunction
  • P0401 Exhaust Gas Recirculation Flow Insufficient Detected
  • P0402 Exhaust Gas Recirculation Flow Excessive Detected
  • P0403 Exhaust Gas Recirculation Circuit Malfunction
  • P0404 Exhaust Gas Recirculation Circuit Range/Performance
  • P0405 Exhaust Gas Recirculation Sensor A Circuit Low
  • P0406 Exhaust Gas Recirculation Sensor A Circuit High
  • P0407 Exhaust Gas Recirculation Sensor B Circuit Low
  • P0408 Exhaust Gas Recirculation Sensor B Circuit High
  • P0410 Secondary Air Injection System Malfunction
  • P0411 Secondary Air Injection System Incorrect Flow Detected
  • P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
  • P0413 Secondary Air Injection System Switching Valve A Circuit Open
  • P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
  • P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
  • P0416 Secondary Air Injection System Switching Valve B Circuit Open
  • P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
  • P0418 Secondary Air Injection System Relay A circuit Malfunction
  • P0419 Secondary Air Injection System Relay B Circuit Malfunction
  • P0420 Catalyst System Efficiency Below Threshold (Bank 1)
  • P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
  • P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
  • P0423 Heated Catalyst Efficiency Below Threshold (Bank l)
  • P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
  • P0430 Catalyst System Efficiency Below Threshold (Bank 2)
  • P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
  • P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
  • P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
  • P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
  • P0440 Evaporative Emission Control System Malfunction
  • P0441 Evaporative Emission Control System Incorrect Purge flow
  • P0442 Evaporative Emission Control System leak Detected (small leak)
  • P0443 Evaporative Emission Control System Purge Control Valve circuit Malfunction
  • P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
  • P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
  • P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
  • P0447 Evaporative Emission Control System Vent Control Circuit Open
  • P0448 Evaporative Emission Control System Vent Control Circuit Shorted
  • P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
  • P0450 Evaporative Emission Control System Pressure Sensor Malfunction
  • P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
  • P0452 Evaporative Emission Control System Pressure Sensor Low Input
  • P0453 Evaporative Emission Control System Pressure Sensor High Input
  • P0454 Evaporative Emission Control System Pressure Sensor Intermittent
  • P0455 Evaporative Emission Control System Tank Detected (gross leak)
  • P0460 Fuel Level Sensor Circuit Malfunction
  • P0461 Fuel Level Sensor Circuit Range/Performance
  • P0462 Fuel level Sensor Circuit Low Input
  • P0463 Fuel level Sensor Circuit High Input
  • P0464 Fuel level Sensor Circuit Intermittent
  • P0465 Purge Flow Sensor Circuit Malfunction
  • P0466 Purge flow Sensor Circuit Range/Performance
  • P0467 Purge Flow Sensor Circuit Low Input
  • P0468 Purge flow Sensor Circuit High Input
  • P0469 Purge flow Sensor Circuit Intermittent
  • P0470 Exhaust Pressure Sensor Malfunction
  • P0471 Exhaust Pressure Sensor Range/Performance
  • P0472 Exhaust Pressure Sensor Low
  • P0473 Exhaust Pressure Sensor High
  • P0474 Exhaust Pressure Sensor Intermittent
  • P0475 Exhaust Pressure Control Valve Malfunction
  • P0476 Exhaust Pressure Control Valve Range/Performance
  • P0477 Exhaust Pressure Control Valve Low
  • P0478 Exhaust Pressure Control Valve High
  • P0479 Exhaust Pressure Control Valve Intermittent
  • P0480 Cooling Fan 1 Control Circuit Malfunction
  • P0481 Cooling Fan 2 Control Circuit Malfunction
  • P0482 Cooling Fan 3 Control Circuit Malfunction
  • P0483 Cooling Fan Rationality Check Malfunction
  • P0484 Cooling Fan Circuit Over Current
  • P0485 Cooling Fan Power/Ground Circuit Malfunction
EOBD Generic Fault Codes starting P05xx - Vehicle Speed, Idle Control, and Auxiliary Inputs
  • P0500 Vehicle Speed Sensor Malfunction
  • P0501 Vehicle Speed Sensor Range/Performance
  • P0502 Vehicle Speed Sensor Circuit Low Input
  • P0503 Vehicle Speed Sensor Intermittent/Erratic/High
  • P0505 Idle Control System Malfunction
  • P0506 Idle Control System RPM lower Than Expected
  • P0507 Idle Control System RPM higher Than Expected
  • P0510 Closed Throttle Position Switch Malfunction
  • P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
  • P0521 Engine Oil Pressure Sensor/Switch Range/Performance
  • P0522 Engine Oil Pressure Sensor/Switch Low Voltage
  • P0523 Engine Oil Pressure Sensor/Switch High Voltage
  • P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
  • P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
  • P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
  • P0533 A/C Refrigerant pressure Sensor Circuit High Input
  • P0534 Air Conditioner Refrigerant Charge Loss
  • P0550 Power Steering Pressure Sensor Circuit Malfunction
  • P0551 Power Steering Pressure Sensor Circuit Range/Performance
  • P0552 Power Steering Pressure Sensor Circuit Low Input
  • P0553 Power Steering Pressure Sensor Circuit High Input
  • P0554 Power Steering Pressure sensor Circuit Intermittent
  • P0560 System Voltage Malfunction
  • P0561 System Voltage Unstable
  • P0562 System Voltage Low
  • P0563 System Voltage High
  • P0565 Cruise Control On Signal Malfunction
  • P0566 Cruise Control Off Signal Malfunction
  • P0567 Cruise Control Resume Signal Malfunction
  • P0568 Cruise Control Set Signal Malfunction
  • P0569 Cruise Control Coast Signal Malfunction
  • P0570 Cruise Control Accel Signal Malfunction
  • P0571 Cruise Control/Brake Switch A Circuit Malfunction
  • P0572 Cruise Control/Brake Switch A Circuit Low
  • P0573 Cruise Control/Brake Switch A Circuit High
  • P0574 through P0580 Reserved for Cruise Codes
EOBD Generic Fault codes beginning P06xx - Computer and Auxiliary Outputs
  • P0600 Serial Communication Link Malfunction
  • P0601 Internal Control Module Memory Check Sum Error
  • P0602 Control Module Programming Error
  • P0603 Internal Control Module Keep Alive Memory (KAM) Error
  • P0604 Internal Control Module RAM Error
  • P0605 Internal Control Module ROM Error (Module Identification Defined by SAE J1979)
  • P0606 PCM Processor Fault
  • P0608 Control Module VSS Output "A" Malfunction
  • P0609 Control Module VSS Output "B" Malfunction
  • P0620 Generator Control Circuit Malfunction
  • P0621 Generator Lamp "L" Control Circuit Malfunction
  • P0622 Generator Field "F" Control Circuit Malfunction
  • P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
  • P0654 Engine RPM Output Circuit Malfunction
  • P0655 Engine Hot Lamp Output Control Circuit Malfunction
  • P0656 Fuel Level Output Circuit Malfunction
EOBD Generic Fault Codes starting P07xx - Transmission
  • P0700 Transmission Control System Malfunction
  • P0701 Transmission Control System Range/Performance
  • P0702 Transmission Control System Electrical
  • P0703 Torque Converter/Brake Switch B Circuit Malfunction
  • P0704 Clutch Switch Input Circuit Malfunction
  • P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
  • P0706 Transmission Range Sensor Circuit Range/Performance
  • P0707 Transmission Range Sensor Circuit Low Input
  • P0708 Transmission Range Sensor Circuit High Input
  • P0709 Transmission Range Sensor Circuit Intermittent
  • P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
  • P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
  • P0712 Transmission Fluid Temperature Sensor Circuit Low Input
  • P0713 Transmission Fluid Temperature Sensor Circuit High Input
  • P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
  • P0715 Input/Turbine Speed Sensor Circuit Malfunction
  • P0716 Input/Turbine Speed Sensor Circuit Range/Performance
  • P0717 Input/Turbine Speed Sensor Circuit No Signal
  • P0718 Input/Turbine Speed Sensor Circuit Intermittent
  • P0719 Torque Converter/Brake Switch B Circuit Low
  • P0720 Output Speed Sensor Circuit Malfunction
  • P0721 Output Speed Sensor Circuit Range/Performance
  • P0722 Output Speed Sensor Circuit No Signal
  • P0723 Output Speed Sensor Circuit Intermittent
  • P0724 Torque Converter/Brake Switch B Circuit High
  • P0725 Engine Speed Input Circuit Malfunction
  • P0726 Engine Speed Input Circuit Range/Performance
  • P0727 Engine Speed Input Circuit No Signal
  • P0728 Engine Speed Input Circuit Intermittent
  • P0730 Incorrect Gear Ratio
  • P0731 Gear 1 Incorrect Ratio
  • P0732 Gear 2 Incorrect Ratio
  • P0733 Gear 3 Incorrect Ratio
  • P0734 Gear 4 Incorrect Ratio
  • P0735 Gear 5 Incorrect Ratio
  • P0736 Reverse Incorrect Ratio
  • P0740 Torque Converter Clutch Circuit Malfunction
  • P0741 Torque Converter Clutch Circuit Performance or Stuck Off
  • P0742 Torque Converter Clutch Circuit Stuck On
  • P0743 Torque Converter Clutch Circuit Electrical
  • P0744 Torque Converter Clutch Circuit Intermittent
  • P0745 Pressure Control Solenoid Malfunction
  • P0746 Pressure Control Solenoid Performance or Stuck Off
  • P0747 Pressure Control Solenoid Stuck On
  • P0748 Pressure Control Solenoid Electrical
  • P0749 Pressure Control Solenoid Intermittent
  • P0750 Shift Solenoid A Malfunction
  • P0751 Shift Solenoid A Performance or Stuck Off
  • P0752 Shift Solenoid A Stuck On
  • P0753 Shift Solenoid A Electrical
  • P0754 Shift Solenoid A Intermittent
  • P0755 Shift Solenoid B Malfunction
  • P0756 Shift Solenoid B Performance or Stuck Off
  • P0757 Shift Solenoid B Stuck On
  • P0758 Shift Solenoid B Electrical
  • P0759 Shift Solenoid B Intermittent
  • P0760 Shift Solenoid C Malfunction
  • P0761 Shift Solenoid C Performance or Stuck Off
  • P0762 Shift Solenoid C Stuck On
  • P0763 Shift Solenoid C Electrical
  • P0764 Shift Solenoid C Intermittent
  • P0765 Shift Solenoid D Malfunction
  • P0766 Shift Solenoid D Performance or Stuck Off
  • P0767 Shift Solenoid D Stuck On
  • P0768 Shift Solenoid D Electrical
  • P0769 Shift Solenoid D Intermittent
  • P0770 Shift Solenoid E Malfunction
  • P0771 Shift Solenoid E Performance or Stuck Off
  • P0772 Shift Solenoid E Stuck On
  • P0773 Shift Solenoid E Electrical
  • P0774 Shift Solenoid E Intermittent
  • P0780 Shift Malfunction
  • P0781 1-2 Shift Malfunction
  • P0782 2-3 Shift Malfunction
  • P0783 3-4 Shift Malfunction
  • P0784 4-5 Shift Malfunction
  • P0785 Shift/Timing Solenoid Malfunction
  • P0786 Shift/Timing Solenoid Range/Performance
  • P0787 Shift/Timing Solenoid low
  • P0788 Shift/Timing Solenoid High
  • P0789 Shift/Timing Solenoid Intermittent
  • P0790 Normal/Performance Switch Circuit Malfunction
