Old 21-05-2009   #1
Trader Rating: 10
dave has donated!
how did this engine damage happen then?
car came in on back of AA truck having badly over heated, all the plug leads had melted into the head.
I put timing tools it an set it before stripping and it was spot on. belt and tensioner are new. no damage or marks to pistons or bore.
but 2 valves are bent and some thing has been eating away at the head
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 21-05-2009   #2
arc
this is where i stand
arc has donated!
Re: how did this engine damage happen then?
daaaavvee learn to use macro mode on your camera for the closeups
faulty fuel injector leading to uber lean mixture, eating the head and thinning the valve stems behind the valves causing them to bend?
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 21-05-2009   #3
Trader Rating: 10
dave has donated!
macro mode
Old 21-05-2009   #4
arc
arc has donated!
for close ups, normally shown as a little flower looking icon. it alters the min focusing distance for the camera - making closeup shots useable and not all blurred!
press the multipad on the back to the left, that should do it on an s5000
Old 21-05-2009   #5
arc
arc has donated!
more pondering, waterway corroded, hence the hole in head (material fault), water leaked in, hydrolocked, bent valves and then it overheated
Old 21-05-2009   #6
Trader Rating: 10
dave has donated!
i thought hydrolocked bends conrods, if valves was open, water would excape?
Old 21-05-2009   #7
arc
arc has donated!
where does the hole in the head lead to, is it burnt or corroded away? cant see the damage to valves properly, has something fallen in there. you say belt etc are new, who did them - did they drop something inside?
Old 21-05-2009   #8
Trader Rating: 10
dave has donated!
i did them
Old 21-05-2009   #9
arc
arc has donated!
if theres no piston damge tho, then it's not going to impact damage to bend the valves. if there was fluid in the cylinder, then i suppose in theory it could bend a valve (it couldn't all escape quick enough, and so bent the valve. piston def completely unmarked?
the damage (bending aside) seems to be just on the one valve. is it possible that the whatever has gone on in that cylinder has seized the valves into their guides as it has overheated and then the cam has bent the valves?
Old 21-05-2009   #10
Trader Rating: 10
dave has donated!
yeah all un marked
Old 22-05-2009   #11
arc
arc has donated!
come on dave.. better closeup pictures already
Old 22-05-2009   #12
Trader Rating: 10
dave has donated!
i found the flower, still in auto, but with yellow flower?
Old 22-05-2009   #13
arc
arc has donated!
thats macro mode, the camera should now be able to focus properly much closer. make sure you half press shutter button and give it chance to focus before fully depressing it
Old 22-05-2009   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
when did you do it dave? did you put head gasket on right way round....seen it many times before.
Old 22-05-2009   #15
arc
arc has donated!
how can HG do that tho? no mention of new HG, just belt and tensioner
Ever think it can't happen to you? The Beard Leisure Lounge 24 29-08-2008 15:00
(G) Anyone ever had this happen to them?!! gar074 Barchetta 2 29-06-2007 18:23
(T) S Reg Punto Sporting 1.2 16 Val Engine Damage maz31 Punto (Mk2/2b) 4 04-06-2007 21:38
(T) Should this happen??... Seraph Stilo 9 17-06-2006 15:54
Had to happen surfin_fella Leisure Lounge 24 18-09-2004 22:49
