Thread Tools
Old 22-03-2007   #1
Aftermarket headunit
Hi Iv been reading up on this in the forum, but what im reading is that if installing a new headunit, it will always be on either with or without the ignition being on unless u have connect nav(but then why change?). this to me sounds a silly stilo way, so im just asking for a deffinate answer that there is no way of getting an ignition feed into the stereo and make it work like stereos should.
thanks
Lowered by 50mm 'when I sit in it'
Rear spoiler 'only if boot is open'
Blacked out windows 'when its dirty'
Dumpvalves 'when Michael Winslow is in the car'
TrackyG3000 is offline Reply With Quote Quote
Old 22-03-2007   #2
Scorpion King
CraigB has donated!
Re: Aftermarket headunit
I dont know much about the things that make cars go, but surely you must be able to disconnect the live from the ignition and run a direct live to the head unit from another source (ie the battery with an inline fuse), thus enabling you to turn it on and off manually as you wish. I could be wrong but I'm sure this should be possible as it is in other cars.
CraigB is offline Reply With Quote Quote
Old 22-03-2007   #3
thats possible but what im reading is if u want it to go off with the ignition then there are problems
Old 22-03-2007   #4
Baah silly stillo. where can an ignition feed come from to make this work?
Old 22-03-2007   #5
ChrisMClark has donated!
Just don't do what a mate of mine did.....
Take a live feed from the fuel pump......
2007 GP 1.4 8v Dynamic Sport daily
2004 Alfa 147 2.0 TS project
And a history of Mk1 Punto and 2 Stilos.
ChrisMClark is offline Reply With Quote Quote
Old 22-03-2007   #6
im thinking possibly cig lighter
Old 22-03-2007   #7
It's a possibility, big hairy great fuse and wiring loom for that
I personally like the stereo being totally independant...until the day I leave it on
Old 22-03-2007   #8
i take it its different for all stereos but to do this i take it i get the stereo red power wire and ignition wire stick em in the same hole which conects to the stilos power and hey presto power alll the time or at least until power is off or face plate is removed?
Thread Tools
Post your aftermarket headunit TomEdwards I.C.E 2 15-09-2005 20:29
(T) Stilo Changer with after market Headunit Bo~Select@ Stilo 0 12-02-2005 08:52
