I've been through this with mine and discovered nobody knows how to adjust them.
Take it to a good dealer.
Well spotted That and the regular plastic adjuster should provide full alignment.
But why do you want to adjust them?
On mine it turned out to be nothing more than a badly seated bulb
I adjusted mine both vertically and horizontally, it's simple
If you look behind the headlamp you will see two white pins sticking out, one behind the high beam and one behind the low beam. If you want to adjust the vertical alignment, you will need to turn the pin behind the low beam with a small spanner clockwise for up and anti-clock wise for down. To adjust the Horizontal alignment turn the pin behind the high beam in the same direction as you want to go.
You need to set the car on an even surface about 20ft from a wall. Done mine myself and there perfect now
Some times it will look like the beam isn’t moving but, trust me, it is!
CaRcAzY
That's a very interesting post.If you look behind the headlamp you will see two white pins sticking out, one behind the high beam and one behind the low beam. If you want to adjust the vertical alignment, you will need to turn the pin behind the low beam with a small spanner clockwise for up and anti-clock wise for down. To adjust the Horizontal alignment turn the pin behind the high beam in the same direction as you want to go.
So you're saying you track BOTH dipped AND main beam together :chin:
Presumably there must also be some adjustment to change main beam relative to dipped or is this simply not possible
