| Thread Tools |
![]() | #1 | ||
Posts: 28 Thanks: 0 Trader Rating: 0 | New Yellow JTD owner with a few rattles Hello All I picked up my 54 plate 3 door Stilo 1.9JTD in Yellow yesterday! Previously drove a Smart Roadster (yellow of course) which was absolutely dreadful! I must say I am VERY impressed with the Stilo so far! Apart from a few rattles (passenger side dash at low speeds and behind speedo somewhere) any hints and tips for a newbie? Thanks! Guy
![]() | #2 | ||
![]() | re: New Yellow JTD owner with a few rattles Hello All I picked up my 54 plate 3 door Stilo 1.9JTD in Yellow yesterday! Previously drove a Smart Roadster (yellow of course) which was absolutely dreadful! I must say I am VERY impressed with the Stilo so far! Apart from a few rattles (passenger side dash at low speeds and behind speedo somewhere) any hints and tips for a newbie? Thanks! Guy
![]() | #3 | ||
Posts: 28 Thanks: 0 Trader Rating: 0 | re: New Yellow JTD owner with a few rattles They seem fine! Is there any way of curing those rattles? more of a creak than a rattle, or do they just come and go? the roadster used to have similar rattles which used to just come and go. I was sick and tired of the roadie being so unreliable and buying a Fiat was a bit of a leap of faith, but the Stilo is just so good looking, especially in yellow, i couldnt resist! The roadie was an 05 plate and in 20 months had the following. 1) Broken gearbox after 2 weeks 2) Engine misfire x 2 3) Leaks from wing mirrors, and roof, remedied with a new roof. 4) Same as number 3 a year later! 5) Water in the back light cluster screwing up the electrics (headlights flash when pressing the brake!) 6) Headlights only changeable at the dealer. 7) Leaks resulting in saturated carpets which rusted the seat rails! Not brilliant considering they were meant to be built by merc! Anything particular on the Stilo worth looking out for? I have done a bit of research and it seems that the Diesels have less problems than the petrols, and by the 54 models most of the main niggles had been sorted out. Anything else worth looking for? Guy
![]() | #4 | ||
popping out ![]() | re: New Yellow JTD owner with a few rattles Only things to look out for really are - make sure the spring recall has been done (which it probably has) - move the overboost valve to the battery box and get a remap ![]() I had the rattle behind the instrument cluster which annoyed me that much that I kind of hit it and made a cracking noise when pulling off for a couple of months but now it's stopped ![]()
![]() | #5 | ||
Posts: 28 Thanks: 0 Trader Rating: 0 | re: New Yellow JTD owner with a few rattles Only things to look out for really are - make sure the spring recall has been done (which it probably has) - move the overboost valve to the battery box and get a remap ![]() I had the rattle behind the instrument cluster which annoyed me that much that I kind of hit it and made a cracking noise when pulling off for a couple of months but now it's stopped ![]()
![]() | #6 |
![]() | re: New Yellow JTD owner with a few rattles Look at the front suss. springs, and it should be pretty obvious. The recall was a clamp fitted to the bottom of the spring. It's a round disc with flaps bent up to contain the sring in the event of a snap. As for the valve I've got no idea! Welcome to the Stilo fold by the way...you're one of the priveledged people now ![]()
__________________ 2007 GP 1.4 8v Dynamic Sport daily 2004 Alfa 147 2.0 TS project And a history of Mk1 Punto and 2 Stilos. |
![]() | #7 | ||
popping out ![]() | re: New Yellow JTD owner with a few rattles spring recall - your front spring cup should look like this https://www.fiatforum.com/attachment...chmentid=22717 with the mecano retaining cup bolted on. overboost valve - look at this thread and my pics on the second page https://www.fiatforum.com/stilo/8922...veryone-2.html
![]() | #8 | ||
![]() | re: New Yellow JTD owner with a few rattles How amusing, ive recently bought a roadie because i was sick of the unreliability of my stilo ![]()
![]() | #9 |
![]() | re: New Yellow JTD owner with a few rattles ![]() Pity we can't find a solution.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic Last edited by Argonought; 26-02-2007 at 11:58. |
![]() | #10 | ||
![]() | #11 | ||
![]() | #12 | ||
Posts: 13,715 Thanks: 243 Trader Rating: 0 ![]() | ![]() Welcome to stilo ownership ![]() ![]() ![]() ![]() ![]() ![]()
![]() | #13 | ||
Posts: 28 Thanks: 0 Trader Rating: 0 | re: New Yellow JTD owner with a few rattles I'll be there! I'm only up the road! Hangover permitting lol
![]() | #14 |
Posts: 663 Thanks: 17 Trader Rating: 0 ![]() | re: New Yellow JTD owner with a few rattles Here's a tip for anyone with a curious rattle that seems to come from beyond the dash. Open the bonnet and make sure the foam padding located close to the hinges is properly stuck down. The adhesive Fiat use can 'die off' causing it to squeak against the underside of the bonnet. Also, check that the squeaking isnt coming from the rubber seals at the side of the windscreen wiper/airbox intake panel. These should be tucked in and not overlap the front wings. Its sometimes neccessary to give them a little squirt with silicone spray just to stop any vibration squeaking.
__________________ Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet ![]() |
![]() | #15 |
Posts: 172 Thanks: 0 Trader Rating: 0 ![]() | re: New Yellow JTD owner with a few rattles Another tip is just buy a huuuuuuuggggee pair of ear defenders (the type builders use) in a nice matching yellow colour, that way you won't hear any rattles or the annoyed beeps of peoples horns as you zooooooooom past them, ha ha ha ![]()
__________________ Dark Grey '03 Stilo MW Dynamic, 1.8 16v FIAT: Filled with Italian Automotive Technology! ![]() Dont mention stripping or that word RUBBER it only gets him excited NanoSi and an excited Mod is not a nice sight to behold believe you me ![]() |
Thread Tools | |
New JTD 1.9 owner | nodollaz | Newbie Central | 18 | 18-05-2008 15:28 |
![]() | colin07 | Stilo | 1 | 29-06-2006 23:43 |
New 1.9 jtd (115) owner | tomlee | Newbie Central | 6 | 04-06-2006 09:08 |
Hunt for yellow punto owner on car nation | The Negotiator | Leisure Lounge | 73 | 18-07-2005 21:46 |
![]() | JTD Nigel | Stilo | 9 | 05-05-2005 18:28 |
