Hi there,
The central bulb on my header console(the dimmed bulb) does not light anymore. I think I have to change it, because the two projectors on the header console are fine and also the back roof console bulbs light fine. So should not be a fuse problem.
When I say header console, i refer to the central rear mirror console also called by some the overhead console, where alarm's volumetric sensors, alarm aerial and mic are located.
As I have read on the forum I undestand that are some sort of clips that keep the console still. I tried to remove it but with no success. Could somone that managed to remove the console without any damage post some pictures or at least describe the procedure, maybe some schematics?
If I damage the clips, the volumetric sensors will go nuts and the alarm will allways go false positive.
I colud not find any info on the elearn also and my book is in german. Maby I didn't know what to search for on the elearn.
This is the third bulb that I have to replace in 4-5 months. Is this normal for fiat stilo? I had to change a brake bulb, a right front bulb and now this one.
