Hmmmm :chin: I think you're find a lot will disagree
Several horror stories of wreaked calipers on the Forum to convince most people
Sounds to me like you just got lucky (hopefully it will stay that way )
I dont think i was lucky, as the tools that are used are really no difference from pliers, its just that they are stuck in the correct position rather than you manually holding them at the correct position...and in my eyes the special tools are worse, let me explain.....if you use long nose pliers you can feel how easily the callipers turn, where as if you use the tool connected to a socket/spanner it would be so easy to use to much force and twist the calliper when it may be stuck.
Put it this way, if it will not turn by hand (plier) then there is a chance that the calliper is ceased and neads an overhall, you wouldent know this by using the force of a spanner...
anyway thats just my opinion, maybe you agree, maybe you think im wrong, but thats just how i see it...
On this point i would like to say i DO still like specialized tools in other mechanical car areas....
