Hello.
I know there are some posts about this issue on the forum, but I couldn't really find my solution.
Story: The car has had all faults, and after a FIAT tech. changed the ECU etc. under warranty the car has been very stable for nearly a year now.
Anyway, I've got a "low oil pressure - stop engine" warning light about 10 times since this summer. The car has been used nearly every day. This has happened only once those particular days, and always at the day's first start. Strangely most common when the car had been parked in the sun and there was hot???
If I stop the engine and restart it, the problem is gone. Another cure has been to give it a step on the throttle, as it idles at slightly less RPM (very little). Just after this throttle push, the idle is ok and the fault signal dissappears. The fault has never arrived when driving - that would make me scared.
I have never tried to drive off with this warning. There are no engine sounds that shouldn't be there. No tapping noises so far.
It uses almost no oil. The Uno and the Ritmo drank oil steadily as fuel, but this one is very greedy. Oil is checked regulary. The car is a 2002, 1.6 litre. No mods yet.
So what I'm thinking is:
- Faulty signal from the oil pressure sensor.
- Faulty sensor.
- Bad connection somewhere.
- Something's dirty at the intake, causing the lower idling, and then causing an actual low pressure.
- Worst: General low pressure.
But how and where to start. I've never dismantled or done anything on this car. The Uno was kind of simpler to break into pieces and rebuild - like Lego. I have no idea what to clean, what to remove, or where the oil pressure sensor is etc. This ended as a long story, but I took the car to Fiat today to make them check it, and he was sure he would use at least 4 hours, maybe more. Maybe it included two lunch breaks and a shag at the backroom with the female sales woman, but 4 hours + to plug a computer or check the oil pressure was a bit too much. So I need your opinion first. One hour labor at Fiat costs £ 75 GBP, and I really can't afford it if nothing comes out of it...
Help!
Morten.
- Faulty sensor.
Help!
Morten.
