Hi All,
I wonder if anyone can help with this problem. This morning I went to start my car (Fiat Stilo Dynamic 1.8) and nothing happened (no obvious noises) the first couple of times I turned the ignition key. My natural reaction was to try again and on the third attempt it started as normal.
I didn't think that much about this as it had chucked it down all night so I just thought the car might be a bit cold / damp.
Tonight when I went to leave work the car started ok but as I pulled away the computer started beeping away at me. The messages dissapeared pretty quick so I couldn't tell you the exact wording but it was something along the lines of ESP fail, ASR fail and Loose wire. As I say I had just pulled away and was navigating the mass exit of work traffic so it was hard see exactly what was said. The dashboard ESP / ASR lights lit up also.
I pulled the car over to the side and stopped the engine. When I tried to start it again the car was dead. I couldn't tell if the ignition relay was clicking as all of the passing traffic was making too much noise. I gave the car a couple of minutes and tried again and it started ok, so I drove home.
Does this sound familiar to anyone? I can't see a loose connection indication in the manual, can anyone suggest which connection and if it is something I can check myself?
This might be totally unrelated but last month the car developed a new feature that caused the windows to wind themselves down even when the ignition wasn't turned on (ie whilst you are in Tesco or asleep!). It has been to the dealer and had that fixed.
Is this the start of bad things???
Cheers,
Steve
Cheers,
Steve
