Old 19-10-2006   #1
SchooweeNick has donated!
RECALL: Service Solution for Suspension Springs
Fiat have just released a recall to do with the front springs on all stilo's from start to chassis 00644197.
If you dont receive a letter and your chassis number is below the above then contact your local dealer.....
Just thought I'd let you know..
SchooweeNick is offline Reply With Quote Quote
Old 19-10-2006   #2
Super LOL!
Stu DemonD's Avatar
Trader Rating: 1
Stu DemonD will never be forgotten
Stu DemonD has donated!
Jigsaw: Chess Pieces Champion
Re: Stilo spring recall
Cool - ashame mine are long gone - OR does the recall involve any other work?
See you next Tuesday
Stu DemonD is offline Reply With Quote Quote
Old 19-10-2006   #3
sgh1970 has donated!
Fitted lowered springs after mine snapped.
Like stu asks,is there any other work to be done.
sgh1970 is offline Reply With Quote Quote
Old 19-10-2006   #4
Yeah the recall is a service solution...
It add's a plate to the shock to stop a breakage affecting the tyre's...
"On some fiat Stilo models under environmental conditions that require intensive use of salt on the roads, corrosive deposits may infiltrate the rubber plate supporting the front suspension spring, starting seats of corrosion which may lead to breakage of the spring after a period of time.
To avoid damage to the tyre should a spring break, a service solution has been identified which involves fitting a plate to contain the spring."
Thats word for word.
It appears that its not so much a problem with the metal more like other factors which can speed up damage to the springs.
Worthwhile getting it done by the sound of things...
Old 19-10-2006   #5
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
PNL replaced his with OE springs didnt he? perhaps a refund/freebie is in line?
Old 19-10-2006   #6
Would it still be worth doing even though ive changed my springs
Old 19-10-2006   #7
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: Stilo spring recall
When my spring snapped nick it didnt snap at the bottom but two coils from the bottom so what good will this plate be when the brake is Not at the bottom sounds like a cop out to me TBO
PNL is offline Reply With Quote Quote
Old 19-10-2006   #8
Trader Rating: 1
Alien Terminator Champion, Alpha Bravo Charlie Champion, Arkanoid Champion, Rock Face Rescue Champion
blast i'm affected
anyone know if its a while you wait job or leave your car for a week job???
i bought my car from your garage nick so i might run it down to you (need to order some roofbars,paint and sill kickplates anyway)
kev1 is offline Reply With Quote Quote
Old 19-10-2006   #9
It looks like where the lowest part of the spring tapers in the shock absorber base it is smaller in diameter to the widest part of the spring so in theory if it breaks at the thinner part the spring could drop over the base plate...
The plate to be fitted makes the base plate wider than the spring so that cant happen... I'll try to post a pic later..
But I'd get it done on all cars just in case as uprated springs might not go but if they did there still be the same consequences and if not just to get it off the recall register and stop the damn letters from fiat...
Old 19-10-2006   #10
It looks like an hour or two's job... (sorry techs if I'm wrong)
Probably be a leave it with us for the day type thing as we're gonna get a fair few of these to do... ! Make sure you ask for me when you wanna order those parts mate and I'll sort a good price for you..
Old 19-10-2006   #11
Mexico
Quote Originally Posted by SchooweeNick
Does any body for sure if FIAT keeps a look at the forum?
http://img407.imageshack.us/img407/9811/michaelgf3tz3hz3.jpg PERMAGRIM CLUB
Athos is offline Reply With Quote Quote
Old 19-10-2006   #12
PNL
Banned
PNL's Avatar
PNL has donated!
On Fiat OE springs the top and the bottom of the springs are smaller in diameter and the springs taper as they spiral to which makes compression with the ordinary type of compressor a bit fiddly you probably have a hydraulic press type there with you Nick the job then is simple. Now what about if our cars havnt got the fiat struts fitted but a standard strut of another manufacter will this plate still fit those struts ?
Old 19-10-2006   #13
Bye Stilo, Hello Doblo
french bean has donated!
Germany
I'm confused. Surely the springs will be of a different specification depending on type of Stilo, 1.2 3 doors having a lighter spring than a JTD MW. So why would they recall all types when a bit of historical analysis will show which are more prone to failure.
french bean is offline Reply With Quote Quote
Old 19-10-2006   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by Athos
Does any body know for sure if FIAT keeps a look at the forum?
Why would they?
SchooweeNick.....its a hour job (2 parts of half hour each) but if car could be left few hours it would be appreciated.
Old 19-10-2006   #15
hi,
My car is affected by this recall but i'v never had a car thats been recalled.
So it's all abit new.
Where does the letter come from ?
Do i have to take it back to the dealer i bought it from ?
If i don't get a letter and have to ring the dealer is there a recall number i can get from somebody to quote to the dealer ?
cheers
purpleronnie is offline Reply With Quote Quote
12,000 mile service... OH NOOOOO! Nuova500 Garages 19 20-08-2007 15:18
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 23:20
MOT + Low Mileage service = Good? [timko] Lets Talk FIAT 8 29-11-2005 16:09
(T) Service question dropthepuck Stilo 3 25-05-2005 11:35
Customer Service gone wrong... Gav Garages 1 11-03-2003 06:25
