I can see this could go on for a bit
NumanR said:
ABZ, I dont think that Stilo springs "shatter for no apparent reason", the technical reason for the failures is due to corrosion which has been caused by salt being used on the roads. This attacks any weakness in the springs covering and this causes the failure. This problem has not occured in countries which do not spread salt on the roads during winter. Its also possible that wheel acid cleaner may contribute if it were not washed off properly..
Fair play, that's the technical explanation of
why it happens but I'd hardly consider it a good reason. I'm saying that it simply should not be happening at all, but I recognise there's no point in shooting the messenger in this instance.
NumanR said:
I do not have a "unique" perspective, I just feel that this is being blown out of proportion. I tried to give you examples of the numbers that we are talking about regarding the failure rate. As a dealer I am, I suspect, in a much better position to judge this than a customer, as I have more information available to me.
But surely it's clear to you that you
do have a unique perspective - as a DET you have all the facts and figures in front of (or available to) you on the numbers of cars the 'problem' is likely to affect; information most others on this forum simply do not have. So your perspective is one of informed awareness wheras others such as I are merely aware - usually by springs shattering in my case
From a FIAT DETs perspective I can see that you might consider that this subject is getting blown out of proportion. I'd choose to disagree with that unique perspective as there is the potential for a serious incident to befall a Stilo owner with this weakness in the springs.
NumanR said:
I tried to give you examples of the numbers that we are talking about regarding the failure rate. As a dealer I am, I suspect, in a much better position to judge this than a customer, as I have more information available to me. If my opinions are not agreed with, that is understandable, but do not for one minute doubt my technical qualifications to make a statement of a technical matter on a subject regarding a manufacturer I have been working for during the last ten years and also on a product which I actually own.
Hmmm - yes, you did try but I must be thick as the point you were endeavouring to make was lost on me - other than you're getting a might tetchy there aren't you NumanR?
Not for one minute have I doubted or queried your technical background.
The way you're approaching what is, for some of us (and potentially all Stilo owners) a very touchy subject I think is a tad (how shall I put it...?) unusual. Handily we have (so far) managed to air our different views on this forum without the need for heavy handed moderation, but don't suggest for one minute that I have queried your background or competency to discuss the subject. Frankly, whilst I respect your opinion, I think your view on this topic sucks.
I can only imagine what you think of me and the others who have contributed to this thread and had the misfortune of a suspension failure or two - perhaps reckless irrational scaremongers (or something like that) which is fine by me - with two broken spring incidents behind me
I think we should agree to disagree on this one
