Technical Radio. no sound
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
John57
surrey
Hi, I`m in the process of repairing a damaged Stilo JTD. On the rear or the Radio unit on the group connectors, the bottom block has multi wires about 50cm going off to a 20 pin black plug dangling behind thr dash Does anyone know where this plugs into, as the radio appears to work but no sound is coming from the speakers. Thankyou:)
Hi again, When the Car was delivered from the Breakers, The Passenger floor mat was loose also the right side plastic cover had been removed. Does the Stilo have a Amplifier box or something under the mat ? for the black plug to connect too, which is missing on mine! Thanks, John
