Technical wires in window rubber seal
stiloryan
wakefield
hi guys hope you can help on both side of the front stilo doors on the inside window rubber seal when you go down to where the door seal rubber touches the tweeter cover thet are tw0 black wires going into the rubber seal what is this for it must end in the seal because on the other end of the seal where the lock pin is there is no wire is it an attenna or something can this be removed from the seal and be put tidyly in side the door trim looks a bit untidy when window goes up you can see all the wires tangled up at a closer inspection the black wier then turns into a silver flexible metal WHAT IS THIS FOR :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
