Technical Can it just be the exhaust? Help appreciated...
ianbloke
Lover / Hater
Hoping for some help with the missus' stilo ('02 1.6) from some knowledgeable folk. Basically the "engine problem-hand your wallet to Fiat" light came on, on her journey home. Only a day ago I noticed her exhaust blowing (Fiat not missus). Was wondering if this is the 'engine problem' - had what sounds to be standard zorst problem symptons of hesitating & missing a bit.
The blow seemed to come from the frontpipe - perhaps this flexible joint Stilo drivers enjoy so much?!
Need to check its OK to make the 20 mile trip to Fiat. Any help with be very gratefully recieved....may prevent a bit of ear GBH :D
You'll need to get someone to read off the fault codes stored if there are any. Hesitation and misfires don't sound much like exhaust blowing problems although exhaust blowing can throw the lambda readings out and cause fuelling problems depending on where the blow is and how severe
You'll have to fix the exhaust anyway and then get the fault codes read to get the answers
