Ok, here's one for you...
'02 1.8 Dynamic 3 door
When going under normal braking, the pedal reaches (what i percieve to be) the end of travel; and everything's fine and dandy. However, under heavy braking, i hit the brakes a little harder and it travels the same amount, but sometimes when reaching the same point, it travels slightly more.
It's almost as if it hit against something, and when heavy braking it knocks past it as i can feel it knocking or grinding against something when it does this. It's kinda hard to describe as i've never felt it before on any car. As you know it gets harder to press the pedal when it reaches the end of the travel, this happens, then suddenly - for a split second - it depresses further quite easily and reaches a second end of travel.
Anyone else got this, or is it the ABS kicking in?! It doesn't lock up and stops fine - it's just a little disconcerting when the pedal moves a little further too easily under heavy braking!
Cheers guys
Cheers guys
