- Sep 12, 2003
- 46,073
- 7,134
Croma is ok - see the Croma thread in 'Other Fiats'
I still want a Brera
Stuart DemonD said:Of course :slayer: the Croma had a range of 130 miles this morning - now having done 60 miles in it, the range is still around the 100 mark although I may drop a fiver in it tomorrow morning
I dropped the wipers down - not sure if they will fit, I only bought them cheap after someone posted a thread on here :chin:
Stuart DemonD said:Getting to enjoy the Croma now
Stuart DemonD said:quite weird taking your foot off the brake on a hill, and the car remaining stationary.
Stuart DemonD said:Well, I pulled the bonnet release on the Croma earlier, and did spot similarities on it :chin: BUT Rich has got one for me, so sorted
Exactly - I will probably do that, even though I have a main PO about 30 yards from where I work, so fairly convenientrroope said:Well the good side of having a new MOT means you can get your road tax online now
Shminkypinky said:So as stated my car 2002 Stilo Dynamic has failed its MOT on:
1. Rear brake pads need replacing.
2. New handbrake cable required (current one is damaged not sure which one LHS/RHS)
Fiat have quoted me £87.00 all in for handbrake cable and £120.00 for pads and if I get repairs done there they will not charge for re-test! so £207.00.
I have until 1st July to sort out but am away on 26th-28th June so dont have much time.
Should I try myself as parts will cost 15.00 for cable and 27.00 for pads but haven't a clue how to do either.
Can any one tell me if the rear pads are easy to do and will I need any special tools. (I have searched the Forum but couldn't find much) and again same with the brake cable.
Thanks for you opinions or advice
tkmking said:Right, my turn today!
Failed on:
Front anti-roll bars worn £100something
Rear tyre's worn
Observations
Rear wiper's starting to crack
front pads are worn thin
Anyone else had this anti-roll bar problem picked up - and what is this special tool you speak of, a birmingham screwdriver?! ;o)
Oh, and can anyone recommend any good pads?
wotnowarninglight said:Anti-rollbar, would assume the links which are common 'wear and tear' item - warranty wouldnt cover it so paid fiat to do mine @ £118 odd as I wasnt sure about the effects of the roll bars torsion. Rear tyre, assume outer edge chamfered off... also too common! Rear wiper, chop a universal 20' cut to size refill blade in half, feed into arm and have a spare for next time! Brake Pads - got Delphi / TRW pads off Lucas Service UK - £16 + VAT Fronts & £13 + VAT rears... picking caliper wind back tool up later (£7.39) from my local motor factors - like this one:
http://www.drapertools.com/b2c/b2cbrowse.pgm
Just gotta find me some time to fit the pads then... Good luck, your motor shouldnt cost too much to put right...
