Technical stilo lights and airbag warning
bozzy said:
Tim_T, thats a pretty in depth analysis, may I ask what your background is? Have you some Fiat experience?
It's always comforting to see techies on here.
:chin: yes I was thinking the same there Boz it is always good to have the techs to help us mear mortals :D
I am a time served Mechanical fiter and also qualified instrument mechanic
For 13 years I was Fork lift truck Service Engineer ( Multidisciplined) covering Both I.C.E powered and battery powered Trucks so used to fault fiding, computer diagnostics etc. Sorting out Naffed wiring looms, control modules etc.
Presently back to Maintenance Fitting at Corus Steelworks Scunthorpe
Well great to have you here mate we cant have enough advise from people like yourself and as an ex steelworker[fab/welder] a big hello (y)
If its Main Beam this is similar to my previous post Main Beam gets Negative from computor to energize Relay (T2) when Main beam selected on Stalk which sends signal to body computer.
Fuses for Main beam are F14 & F15
The sockets on the Relay mounting (85) & (86) are the Relay coil supply
So print out my previous post and use above in it for testing main beam.
Be sure not to pull the Radio fuse unless you have Radio Code/CD changer code on hand.
If you wish I,ll Head Light & Main Beam scan circuit diagrams/ description and then email to you if you wish i¬ll be tommorow cos I am just going to work on afters.
Thanks to all for the replys.
Just talking to members of the forum seems to have scared my car as it has behaved impecably since i posted the problems. I will uplug an reconnect the connections under the seat as suggested to correct the airbag warning next time it happens.
As to the other checks and things i think i may have to take it in (its still under warrenty) as i dont think i would be clever enough to carry them out. If the problems return and i have to take it in to be checked out i will let you all know what the cure was if it is indeed cured.
John
Ps to clarify things its only the (as i now know ) the main beam that goes on by it's self no other light front or rear. If you then turn on the lights while this is going on all the lights come on as normal but you have both dip and main on together and trying to use dir or main on the stalk has no effect untill it sorts itself ou then all works ok untill the next time it happens
Glad it's stopped playing games for the moment.
worth mentioning though John that on the Stilo the main beam and the dipped beam do come on together when you select main beam. That makes your particular fault even trickier to analyse. :confused:
So it would look like nothings happening if the main beam is jammed on.
i.e. you select dipped but main beam is already on
you select main beam but dipped lights come on with them as normal
If you select front fog lights with main beam on then the dipped lights should go off. Weird i know. Less trouble wiring up a Christmas tree
Why anyone wants main beam with fog lights? :confused:
Answers on a postcard please
Having in the past owned and driven daily cars like Alfa Romeo Guila GT's, Fiat X1/9's, Lancia Fulvias's etc. and the like...................you find these problems are known as Italian 'quirks!' :eek:
Hi all i spoke to soon
Car decided to put the headlights on with the inition turned off (its never done that withe the ignition off before ) on Sunday so came home to a flat battery managed to bump it off and have taken it to the dealers will let you all know what they come up with thanks again for all the helpfu;l3l reply2s
John
Hi All j
Just had the garrage on the phone seams it is the same problem as rroope's mam had faulty fuse box.
New one on order said they will have it fixed for me by Thursday i live in hope as the other half is not amused with me taking her car to get to work.
Thanks again for all your suggestions much appreciated.
John
If she doesnt want you to go to work then make the most of it my son and have fun on here with us ;) :D
efrules said:
Hi All j
John
If its under warranty get them to make sure D4 is good too - might as well whilst they're there!
Love to take the time off but I have a wife 2 yorkshire terriers 3 kids( who are for life not just for christmes so om told though i have tried to send them back) and 4 grankids to support or at least it seems that way Somtimes.
Garrage just rang cars fixed not bad since i only took in in on Sunday and it wasent looked at untill monday and fixed! by Tuesday.
John
John
I know exactly what yoou mean John when you say ALL those to support my Oldest has just come back home to stay :bang:
