Re: Headlight Motor Alternative Fix
Coo! That wasn't your day then
Going back to the motor, it's a bit chicken and egg with what goes wrong with the resistor and the securing clip. If the resistor fails then the motor doesn't know when to stop and drives the screw jack down until the resistor clip becomes detached. Equally if the clip on the resistor becomes detached first then it has the same effect and the screw jack just drives down until it gets jammed. So check the clip and the resistor range to see which is the cause
You can connect it and check it's working before finally inserting back into the headlight
