Anybody know where to start on removing a front strut, I see only a single bolt attached to the mounting dome in the engine bay. The rest I am cofortable with. Cmon T14086, I need you again.
PNL said:Thats easy my little yellow friend look at the top and you will see that an allen key fits inside the bolt thats sticking up its usually about 7mm the allen key will hold that still while you undo the nut is that all you want
gained an inch Arrrrr but that could be growing pains my little yellow friendbozzy said:"thats easy my little yellow friend"
Isn't that what you said?
Since they did my spine op I have gained an inch so I aint the shortarse I once was.
bozzy said:Do the fat springs go front or back?
bozzy said:Yep, front it is, Eibach -30mm but the original springis now a good 100cm longer. Just called Eibach, code on the spring says V goes front, HA rear. There you go, cheers Phil.
T14086 said:Take it you got struts off then?
wolfracepunto said:DIY spring fitting is always a pain in the arse Ive done it to both my cars...wont be doing it again.
