randiscipio
I've read most of the recent topics and can truly say, hand on heart my problems seem trivial compared to some of you.
I've had my Broom Yellow Abarth since July 2002, had to accept the fact that Fiat were unable to fit Xenons at that time.
17 months in to ownership I've found that my 5 disc changer which is fully loaded just flashes at me and doesn't que up any of the CDs. I've checked to make sure I haven't "accidently" put two discs in the same slot.
Could find nothing on the web from Blaupunkt to explain why all the slot numbers flash at the same time from green to orange.
Maybe some one out there has had the same "feature", F.A.U.L.T.
and can advise.
Also recently a couple of warnings appeared
1) Auto Gear selector Failed
So I put in manual and carried on. When I got home and switched off and on again the warning light went away. What a surprise.!
2) Airbag Failure sensor under the front passenger seat now comes on when the seat is moved for rear passengers, I switch the engine off, fiddle with the connectors and VOILA! its fine.
(STILO Abarth 2.4 20V *3dr*Broom Yellow*Skywindow*17" Rims*Full HI-FI etc. etc. as keep pointing out to the BMW owners that paid a fortune for a car with a steering wheel as standard)
Good to see there are that many of us about.
MY 5th FIAT.
[8D]
randiSC
and can advise.
MY 5th FIAT.
[8D]
randiSC
