Here's an Examiner with all the attachments.
http://cgi.ebay.de/Fiat-Alfa-Lancia...ryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
TRANSLATION
This tester is used in the workshop used for diagnosticwork on above mentioned marks. One can test among other things the different ecu's (e.g. engine, transmission, abs, airbag, instrument panel, electrical power steering, more bodycomputer u.s.w.) do active diagnoses , software update by means of flashing, parameters read, service intervals reset, similar measurements among other things with oscilloscope functionby means of inserted DVOM map, turn signal activate with open/close, keys code and much more besides! With inserted CAN upgrade map for modern vehicles with CAN net. Inserted one floppy -und CD Rome disk drive, removable touch screen with cable, connection for printers, key board and color monitor. Many spoke to select (naturally also German!) - installed (rel. 5,40) inclusive adapter 230v, battery cable 12v, 3 pin VCI cable, MPX 97 multiplexers to the k-lines, CAN eobd map and cable 16 switch last software-Version polig, DVOM map including test lead, 4 different guidances for the Examiner, back up cd's for basic program and the 5,40 releases software. The Examiner is until today in the use been for my private car and functioned 100%. I'm selling the Examiner because I bought an Examiner Smart .
It's all a bit of detective work but the program is updated by flash which I guess is the "Release" program
