![]() | #1 | ||
Posts: 82 Thanks: 0 Trader Rating: 0 ![]() | remote central locking ok got a stilo 52 plate but no remote key fob what are the chances of getting a blank key having it cut and copied from old key or would a genuine Fiat remote central door locking kit made by META alarms. that turns your factory fit cental locking into a one touch remote control operation. work on the stilo it consists of a relay with areial and fobs that plugs into fuse box to replace origanal relay for central locking? your thoughts please o wise ones
![]() | #2 |
![]() | Re: remote central locking The remote control central locking system is integrated into the Body Computer from what I understand, all UK Stilo's have remote locking so you'll need to go to FIAT and get an original remote. Those kits you mentioned are not compatible with the Stilo.
__________________ Last FIAT: 08 Bravo TJet Sport, Maranello Red Retrofitted: Blue & Me Nav, Chrome Handles Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion ![]() Sister-in-Law's 58 GP 1.4 Eleganza, Azure Blue, Cimate, Parking Sensors Previously: Mk.1 Punto, 2x Brava, Barchetta FL, 5x Stilo, Nuova Bravo, and more . . . |
![]() | #3 | ||
Posts: 439 Thanks: 0 Trader Rating: 0 ![]() | Re: remote central locking if you want an alarm get a genuine fiat 1 then get a new central loking key as well then you dnt need a fob because the alarm runs off the remot key. wel i think thats rite
![]() | #4 | ||
Posts: 82 Thanks: 0 Trader Rating: 0 ![]() | Re: remote central locking yes im not sure if the car has alarm already when you lock doors you get the red light flashing fron the door pin so the only way to do is to get a key?
![]() | #5 |
Posts: 1,242 Thanks: 6 Trader Rating: 0 ![]() | Re: remote central locking Did the car only come with a Single key ? Just that all stilo's have remote Central locking as standard, if if you only have one key the the original remote key must of been lost by the previous owners. The Red light in the door will come on, even with no alarm fitted. It is there to inform that the imobiliser is at least enabled on none alarm models. Also if you can stick stuff into a space above the front interior light I believe that means there is no alarm.
__________________ Scorg |
![]() | #6 | ||
Posts: 82 Thanks: 0 Trader Rating: 0 ![]() | Re: remote central locking yes theres room to place things above interior light
![]() | #7 |
![]() | Re: remote central locking Hence you have no alarm, but have remote central locking fitted, and need to go to FIAT to get the original key for it to work! I expect you may need ID to order it; best phone in advance.
![]() | #8 | ||
Posts: 82 Thanks: 0 Trader Rating: 0 ![]() | Re: remote central locking cheers guys i shall venture into the expensive world of a fiat dealer
![]() | #9 | ||
Posts: 29,985 Thanks: 1068 Trader Rating: 0 ![]() | Re: remote central locking ![]() cheers guys i shall venture into the expensive world of a fiat dealer ![]() ![]() Key fob £42,programming £20....dont forget to bring I.D./proof car is yours so codes can be obtained via ISR.If you want the indicators to flash when locked/unlocked then say so beforehand!
![]() | #10 | ||
Posts: 82 Thanks: 0 Trader Rating: 0 ![]() | Re: remote central locking thats nearly the price of getting the relay earlier mentiond cheap as chips,so all i need is cash old key and id etc
![]() | #11 | ||
Posts: 29,985 Thanks: 1068 Trader Rating: 0 ![]() | Re: remote central locking Did one yesterday....seen the bill,it was £62+vat,alot of dealers will however charge you standard one hour for process so check first as not doubt varies. However if you want to pay us more your welcome to ![]()
![]() | #12 | ||
Posts: 82 Thanks: 0 Trader Rating: 0 ![]() | Re: remote central locking will look into that is it also possable to get a red key before the blue one goes kapput
![]() | #13 |
![]() | Re: remote central locking No need, Stilo's don't use the red key, each key gets programmed into the Body Computer instead now. Like T14086 says, if you want the car reprogrammed so the inidcators flash when you lock/unlock the car they can do it whilst they've got the codes from the ISR to hand; if you decide to do it later, you'll no doubt have to pay again!
![]() | #14 | ||
Posts: 82 Thanks: 0 Trader Rating: 0 ![]() | Re: remote central locking right then just called my wonderfull local fiat dealer 155 pound all in ![]() he put it down to the technology of today ![]() yeah right i said
![]() | #15 | ||
Posts: 29,985 Thanks: 1068 Trader Rating: 0 ![]() | Re: remote central locking ![]() Try another dealer!!!!
Fitting Remote Central Locking Mk3 Punto | Russell | Security | 6 | 18-01-2011 02:29 |
![]() | Wrighty | Punto (Mk2/2b) | 19 | 23-05-2008 14:19 |
BOO Bargains - Remote Central Locking Kits | wimmy | Auction Watch | 8 | 14-01-2008 01:18 |
![]() | Gareth | Bravo / Brava | 2 | 21-08-2005 13:36 |
![]() | m a t t | Cinquecento / Seicento | 1 | 25-03-2004 03:41 |
