Technical remote central locking
bradford
ok got a stilo 52 plate but no remote key fob what are the chances of getting a blank key having it cut and copied from old key or would a genuine Fiat remote central door locking kit made by META alarms. that turns your factory fit cental locking into a one touch remote control operation.
work on the stilo it consists of a relay with areial and fobs that plugs into fuse box to replace origanal relay for central locking?
your thoughts please o wise ones
The remote control central locking system is integrated into the Body Computer from what I understand, all UK Stilo's have remote locking so you'll need to go to FIAT and get an original remote. Those kits you mentioned are not compatible with the Stilo.
if you want an alarm get a genuine fiat 1 then get a new central loking key as well then you dnt need a fob because the alarm runs off the remot key. wel i think thats rite
Did the car only come with a Single key ?
Just that all stilo's have remote Central locking as standard, if if you only have one key the the original remote key must of been lost by the previous owners.
The Red light in the door will come on, even with no alarm fitted. It is there to inform that the imobiliser is at least enabled on none alarm models.
Also if you can stick stuff into a space above the front interior light I believe that means there is no alarm.
Hence you have no alarm, but have remote central locking fitted, and need to go to FIAT to get the original key for it to work!
I expect you may need ID to order it; best phone in advance.
bircia11 said:
cheers guys i shall venture into the expensive world of a fiat dealer
:devil: Yes my willing victim come to us.......dont forget your chequebook:D
Key fob £42,programming £20....dont forget to bring I.D./proof car is yours so codes can be obtained via ISR.If you want the indicators to flash when locked/unlocked then say so beforehand!
Did one yesterday....seen the bill,it was £62+vat,alot of dealers will however charge you standard one hour for process so check first as not doubt varies.
However if you want to pay us more your welcome to:devil:
No need, Stilo's don't use the red key, each key gets programmed into the Body Computer instead now.
Like T14086 says, if you want the car reprogrammed so the inidcators flash when you lock/unlock the car they can do it whilst they've got the codes from the ISR to hand; if you decide to do it later, you'll no doubt have to pay again!
yes it was 73 pound for key and 80pound for programming iasked if they charged for labour he said no but i sahll keep my belt tight hes not having my pants down
sunwin fiat of keighley
anyone know of any dealers in west yorkshire ?
also on eper theres about 4 different key options anyone know what the difference is
the part numbers 71738116 price 41.82 for code 2 key
and code 2 block kit 735319159 price 82.88 GBP
i only want the key?
What?? :eek:
The key is unfortunately now £85 (71738117) for remote control central locking, or £44 (71738116) for just a flip key with no buttons. The Block Kit refers to the key and lock barrels too!
£80 for programming is ridiculous, thats what, 1.5 hours labour? Took my dealer about 15mins when they did a new key under warranty (they wanted the old key too). Don't know how much ISR will charge to release the codes; I ordered the CODE2 card (46514910, ePER price is £2.20) which has the code on it, so I never need to contact ISR again (y)
Try Piccadilly in Wakefield, see how much they want for it all.
bircia11 said:
... but i sahll keep my belt tight hes not having my pants down
Good one, made me laugh! :D
