stripey stilo
Member
i know i am going over old news but i cant make sence of all the threads on this.
i have aquired a connect nav + and all necisary parts
ie. tray
microphone unit
gps/gsm antenna
and steering wheel with controls
now as i can make out you need to change the trays first.
then run gps/gsm antenna through roof lining down 1 of the front pillars and to were the unit will be.
run a 12v ignition live from cigeret lighter to behind the unit.
and install the microphone unit over head as i am using original there should be connecter behind interior light for this.
steering wheel has also got connecter block behind for straight swap from original.
with regaurds to code i understand that this is wat tells the ecu that sat nav has bin installed if i cant get this from seller. how would i aquire.
now i have read on another thread something about a can bus line, this is the thing i am having trouble understanding. wat is the reasoning behind this.
is there any thing else i need to know
your help would be appriciated
ie. tray
microphone unit
gps/gsm antenna
