Old 20-12-2005   #1
Gear stick problem
Probably not specific to Stilos but not being a gearbox expert thought I would ask. Gearstick does not spring back to line up with third and fourth gears. Is this simple to fix or is it gonna cost me? All advice greatly appreciated.
Banks is offline Reply With Quote Quote
Old 20-12-2005   #2
is one with the dark side
Citizen Smith's Avatar
Trader Rating: 1
Citizen Smith has donated!
Re: Gear stick problem
Gear selector on top of gearbox needs lubricating plus a bit of filing due to the shaft and sleeve being too tight.
VW Golf GTi
"power is nothing without control"
Citizen Smith is offline Reply With Quote Quote
Old 21-12-2005   #3
Would gear stick that is real stiff to move accross the neutral area be the same problem? Mines been sitting for 3 weeks, and now its real bad.
Stilo '02, 3dr 1.8 Dynamic.
Passenger side door randomly refuses to unlock. / Driver side door internal door handle link broken. / Timing Variator and/or Water Pump . / Driver Side Inside Door plastic door panel knackered.
"ASR Failure, ESP Failure, Security System Failure, Loose Connection..."
euan is offline Reply With Quote Quote
Old 21-12-2005   #4
Trader Rating: 1
Quote Originally Posted by euan
Possibly - the problem is more associated with Abarth's and Jtd's as they have a higher torque gearbox which is different to the 1.8's.
VW Golf GTi
Old 21-12-2005   #5
thanks. I guess I'll havea look, or else it'll be off to the garage, and I'll be told I need a new gearbox or something.
Old 01-03-2013   #6
Light Seeker
vladof's Avatar
vladof has donated!
Romania
Getting back on this, it seems the problem is more obvious when you don't drive the car for a long time.
Both my stilos were affected, I used to thing this was only an issue with my father's stilo, but it seems mine has done the same after some 2 weeks on not driving it. If you drive the car long enought it would eventually work fine again, but it always comes back if you don't drive the car for some time.
Does anyone know what exactly needs to be lubricated?
Cheers.
______________________________________________
Stilo 1.8 Dynamic, 5 door, 2002, Navy Blue
Stilo 1.8 Dynamic, 5 door, 2002, Nero Moire VR
vladof is offline Reply With Quote Quote
(T) Gear selection problem bikeman Multipla 0 10-09-2005 21:15
(T) Cinq Thumping Out Of 2nd Gear GhostWKD Cinquecento / Seicento 17 22-09-2004 08:06
(T) Tip timing problem? Akeldama Tipo (Classic) 4 01-08-2004 06:54
(G) Multipla Gear Stick & Steering Wheel gazza Multipla 3 24-12-2003 06:12
(S) Gear Knob Pete600 Cinquecento / Seicento 10 08-05-2003 06:33
