Old 1 Week Ago   #1
number plate lights/rear panel
Well the beastie passed another MoT (first time), with only a few advisories.
However that was after giving it a quick check over only to find the bulb warning light on, as one of the number plate lights wasn't working. Of course the screws were rotten and the heads gave way but fortunately trying to drill them out resulted in the remaining bit getting so hot it melted the plastic and the light unit was easily pilled out over the top of the rusty heads. All of which enabled me to clean the contacts (that's all that was wrong) and slot it back in place for the test. So far so good .
For the longer term there's no way the screws are ever going to come out of the 'fitting' from the outside, and the 'fitting' appears to be part of the inside panel of the Boot ?. Adverts on eBay only show the light cluster itself for sale.
Does any knowledgeable soul know how it all comes apart ?, or is the solution to strip out the inside of the Boot panel, and attack it from that end ?
Maxcaddy is offline Reply With Quote Quote
Old 1 Week Ago   #2
Yellow Peril has donated!
Re: number plate lights/rear panel
Yes, get at it from behind. Pull off the lining/cover (held on by press fit only as I recall). Then you can access the nuts that hold on the number plate light unit.
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 1 Week Ago   #3
Ta, as and when it warms up a bit I'll pull it apart .
Old 1 Week Ago   #4
Dean
Zeewulf's Avatar
Zeewulf has donated!
Might worth replacing the screws with A4 stainless steel ones (marine grade), might weather the UK conditions better and not rust as quickly.
Zeewulf is offline Reply With Quote Quote
(T) Rear number plate lights Peat Stilo 4 18-06-2015 11:16
(S) L.ED Rear number plate lights swift Bravo 4 09-02-2015 22:23
(T) Rear number plate lights ramborobert Stilo 6 21-12-2013 13:28
(T) number plate lights/rear boot lock fredbear 500 5 04-02-2013 21:46
(T) Rear number plate lights blown twice.. tk23ho 500 8 01-02-2011 00:17
